Noob queston about my shiny new CBR600 fx
Inno
PostPosted: 14:21 - 18 Aug 2004    Post subject: Noob queston about my shiny new CBR600 fx Reply with quote
I have just passed my full bike test and got myself a CBR600 fx, I am the worst person there is when it comes to the up-keep of my car and now my bike !!!!
My wife fills the car with anti freeze ( I'm that bad ((lazy) Laughing
My question is, on my cbr there are large air intakes on the front, riding in the hot weather there must be flies and god knows what going in there........... where do they go and do I need to get them out or clean the inside at any point ???
Also what other things should I keep on top of (apart from the seat when riding) oiling the chain ect and when ???
Anyone use or see the point of crash bobbins ?
Ta very much
McJamweasel
BCF Junkie
PostPosted: 14:22 - 18 Aug 2004    Post subject: Re: Noob queston about my shiny new CBR600 fx Reply with quote
Yes, and yes.
See here: https://www.bikechatforums.com/viewtopic.php?t=30996
Dusty
King of the Rim
PostPosted: 14:45 - 18 Aug 2004    Post subject: Reply with quote
You probably want to try and lube the chain every couple of weeks, depending on how much riding you have done.
The ram air intakes go to the air box, inside of which there is an air filter. It's probably worth cleaning the air filter every four thousand miles or so, it's surprising how much difference it can make. To get to it you just need to remove the tank and take the top off the air box.
To clean it you can just use warm soapy water, but after it has dried out it is important that you liberally cover it in oil, to stop moisture being able to pass through it so easily and get into your engine.
Other thing that are worth doing regularly include checking the tension of you chain, ideally you want to have about 15mm of play in it.
Tyre pressures are also worth checking regularly, they will make a big difference to the handling of the bike it they are over or under inflated.
Bleeding and cleaning your brake callipers is in my opinion worth doing every four thousand miles or so too.
Gallery
Inno
PostPosted: 15:13 - 18 Aug 2004    Post subject: Reply with quote
Thanks very much......
This will show the wife I wear the trousers doing man things !!!!!!!! Embarassed Confused
Jaz
PostPosted: 17:37 - 18 Aug 2004    Post subject: Reply with quote
Also get a scottoiler fitted, my touring one was an hours labour for the garage to do it as I didnt really fancy messing with the vacume system and some guides said you might need to take the rear wheel off !
not as cheap as a can of lube but a lot less effort.
Trunecka
PostPosted: 20:25 - 18 Aug 2004    Post subject: Reply with quote
Hmm, i'd always seen about 3-4mm suggested. Confused I suppose a decent quality chain as fitted OE to a CBR will easily cope with the extra tension.
"I'm gonna get free, Ride into the sun..."
-The Vines
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
Bendy
Mrs Sensible
PostPosted: 11:01 - 19 Aug 2004    Post subject: Reply with quote
Jammy-G wrote:
I dont see the need for the auto lube, It's more fun and rewarding to maintain your own bike instead of paying for a machine to do it for you.
Depends how lazy you are.
I'm was too lazy to refill my Scottoiler so now I'm doing it the old fashioned way until I get motivated to refill it. Doh!
The last post was made 22 years, 1 day ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.13 - MySQL Queries: 13 - Page Size: 58 Kb
