Honda cd200 benly Timing problems
Usher4566
PostPosted: 18:26 - 29 Apr 2011    Post subject: Honda cd200 benly Timing problems Reply with quote
I have recently brought a cd200 benly to get me to work and back the bike starts okish but every now and agen it seems like it loses it's spark ie revs drop go erratic has any one had this problem .could any one give me advise on checking timings ect .it dies but always re stArts
New cd200 benly owner
Teflon-Mike
tl;dr
PostPosted: 18:41 - 29 Apr 2011    Post subject: Reply with quote
Benley covers a long production history and wide range of ignition system changes.
Is it points or CDi model?
6v or 12v?
Start with echecking the plug caps, then the HT leads, then the Coil, & working back through the system.
Usher4566
PostPosted: 19:04 - 29 Apr 2011    Post subject: Benly Reply with quote
It has a 12v battery so guess 12 volt system when I take side cover off there is a single pick up and a rotor does that meen it's cdi?
Teflon-Mike
tl;dr
PostPosted: 19:50 - 29 Apr 2011    Post subject: Re: Benly Reply with quote
Yes.
And its pretty robust, so if you DO have a spark drop out, its likely to be the CDI unit, or the coil, or teh HT Lead, or a misileniouse earth.
However, benley motors, carburettor problems can often present like sparks.
What carb has it got on it?
Can you be more specific in the symptoms?
Usher4566
PostPosted: 20:04 - 29 Apr 2011    Post subject: Reply with quote
Not sure wat carb will check in morning . Wen it's on tick over revs go up and down .and wen reving it , it sometimes loses revs like it's flooding ? Then picks up agen !
Teflon-Mike
tl;dr
PostPosted: 21:21 - 29 Apr 2011    Post subject: Reply with quote
I suspect it has the CV carb on it.... and its perished or got a tear in the diagphram!
But by remote control... wont bet on it!
Look at that carb though, cos pointing more that way!
Usher4566
PostPosted: 21:36 - 29 Apr 2011    Post subject: Reply with quote
Many thx will Look at carb tommoz some time and keep you posted if find split in diathram.
Usher4566
PostPosted: 08:11 - 30 Apr 2011    Post subject: Reply with quote
Hi carb checked out ok still think wen ride is like I lose spark on one side
Paddy Blake
PostPosted: 08:21 - 30 Apr 2011    Post subject: Reply with quote
I would go along with what Mike says.
The diaphragm may have hardened or have holes in it.
Usher4566
PostPosted: 08:27 - 30 Apr 2011    Post subject: Reply with quote
Hi carb checked does not have a diaphragm it has a float all looks ok
Teflon-Mike
tl;dr
PostPosted: 10:22 - 30 Apr 2011    Post subject: Reply with quote
https://images.cmsnl.com/img/partslists/carburetor-cd125k3_bigma000124e13_f652.gif
should look something like this.
Sounds to me like you have taken the float bowl off the bottom, not looked at the slide, which if its the CV carb, which I believe it ought to be on later 12v CDI Benley, is controlled by a diagphram. (Part 8 in the pic)
As for loosing one spark.... well, the Benley is a 360 twin, both pistons ride and fall in unison, and there is a single spark trigger, becouse it fires every rev, sparking both pots at the same time, via a common coil.
When piston aproaching TDC on compression, and spark occurs, in one pot, lighting the fire for teh combustion stroke, the other pot is coming up on the exhaust stroke, with the exhaust valve open, and exhaust gasses in the cylinder that the spark in that pot wont light. Its called 'lost spark' ignition.
So there isn't really much to cause a timing fault on just one cylinder.
CB125's I have, have 180 cranks one piston up, one piston down, so they cant have common lost spark ignition, they have to have two individual ignition circuits, one for each pot, to time them to the right firing intervals, but on your bike, not so. Its very simple.
And I'd still suspect that carburettor, first.
Usher4566
PostPosted: 12:48 - 30 Apr 2011    Post subject: Reply with quote
Hi many thx for help every one . Carb is different to pic has screw cap on top no diaphragm but good news is found problem was most simple thing spark plugs !!!!! But am very greatfull for all you help
The last post was made 14 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 79 Kb
