| Carl_steveo |
 Carl_steveo World Chat Champion
| SillyMe |
This post is not being displayed because it has a low rating (Boring). Unhide this post / all posts.
 SillyMe Trackday Trickster
 Posted: 09:16 - 20 Oct 2010 Post subject: |
As long as the loom is from the correct year & model of the NSR in question I can't see there being a problem.
They are all 12 volt looms and can't see there being much if any differnces. Could be wrong, we will see.
1989-93 NSR125-R Parts
1990-93 NSR125-F Parts
1994-98 NSR125-R Parts
1999-00 NSR125-R Parts
2001-04 NSR125-R Parts
https://nsronline.tripod.com/ ____________________ Once made equal to man, woman becomes his superior.
The man who says "I may be wrong, but -" does not believe there can be any such possibility
Owned and rode: Honda 100H, Honda MBX 125, Kawasaki AR 125, Suzuki RG 125 Pepsi, Honda NSR125 RK, Honda NRS 125 race bike, Suzuki GSXR 400 Bandit, Aprilia RS 125 O2, Honda CG125, Kawasaki KMX 125, Aprilia RS 125 O6, Suzuki XT225 and now Honda XR 400. ( A few scooters and other dead beats in between) |
| Phoenix |
 Phoenix Twisted Firestarter
 Posted: 12:31 - 20 Oct 2010 Post subject: |
| Esoteric1 wrote: | As long as the loom is from the correct year & model of the NSR in question I can't see there being a problem.
https://nsronline.tripod.com/ |
Absolutely, but the problem is you're not cooking the potatoes correctly, you have to saute them first, then add a little rosemary and maybe some marjoram. I'm not sure though, you might have to boil them actually.
https://www.amazon.co.uk/Food-Drink-Books/b?ie=UTF8&node=66 |
| SillyMe |
This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
 Posted: 13:24 - 20 Oct 2010 Post subject: |
https://img183.imageshack.us/img183/7105/chimpanzeelaughing.gif ____________________ Once made equal to man, woman becomes his superior.
| Carl_steveo |
| SillyMe |
This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
 Posted: 17:21 - 20 Oct 2010 Post subject: |
Only God Knows!
Why is the French horn a divine instrument?
Because a man blows in it, but only God knows what comes out of it. ____________________ Once made equal to man, woman becomes his superior.
| alains |
 alains World Chat Champion
| Carl_steveo |
 Posted: 20:43 - 30 Oct 2010 Post subject: |
| alains wrote: | depense on the CDI , the loom is different if you have a CI626 or a CI639 or a CI626A because the black/yellow and the green are reversed and i think that's the only diffrence between them
32100 KBS 740 ........UK & Irl , IT,SP,Europe (CI626)
32100 KBS 620 .........FR (CI639)
32100 KBS ??? ..........SW,DE (CI626A) |
So is there anything I can do about this. I bought a wiring loom and it's different to the one I had. The only difference is the wiring to the CDI is different. Two of the 4 wires are the different way around, can I just swap the wires to other way so it's correct for the CDI or do I need the CDI that would go with this wiring loom. Or have I got the wrong wiring loom and I need the one that would match my bike originally. I'm confused Alains, I fitted the new wiring loom tonight and the electrics work, I didn't want to start it though because of the CDI, I did try though but it wouldn't fire so gave up. Help mate.  ____________________ Current: Honda Nsr 125
Live: Sunderland
Luke "cant be arsed to read your post, but suck my balls anyway." |
| alains |
 Posted: 21:44 - 30 Oct 2010 Post subject: |
download my file https://www.geneva-racing.ch/~alains/NSRtips.doc
look page 8 you'll see the UK & Fr difference
but you can also look the mark on the CDI and apply the wiring with the CDI
doing it is simple : only 2 wires to cross (green & black/yellow)
- on the 4 wires connector from the main loom , the terminals inside havent a little clip which lock the terminal
- introduce a thin point of tweezers between the plastic and the terminal , push inside while pulling the wire until you feel this wire coming out , that's it
- refitting the terminal dont forget to put the little lock like a "y" then when you put back the terminal you will hear a tiny click
note : when you look the connectors diagram the wiring is behind ____________________ the worst day fishing is better than the best day working |
| Carl_steveo |
 Posted: 21:58 - 30 Oct 2010 Post subject: |
Thanks alot Alains. I owe you about 20 pints.
Also because I keep forgeting, what do I need to finish the de-restriction. I have a de-restricted exhaust and have no carb restrictor. ____________________ Current: Honda Nsr 125
Live: Sunderland
| Nicky.B |
 Nicky.B L Plate Warrior
| alains |
 Posted: 09:01 - 23 Apr 2011 Post subject: |
first of all check your battery (voltage must be more than 12.7V)
if it's down , process charging it following my instructions https://www.geneva-racing.ch/~alains/NSRtips.doc
if battery is good , you must check you contact key and the ground connection (main ground goes on the starter)
the positive entry is red , exit is black
check voltage between red and ground (anywhere on the frame)
if good , put key on and check between black and ground
keep me inform of your results ____________________ the worst day fishing is better than the best day working |
| Nicky.B |
| alains |
| Nicky.B |
| Nicky.B |
| alains |
| Nicky.B |
| alains |
The last post was made 14 years, 349 days ago. Instead of replying here, would creating a new thread be more useful? |
