motor oil: can you use anything with the right specs
czakal
PostPosted: 20:47 - 30 Apr 2011    Post subject: motor oil: can you use anything with the right specs Reply with quote
Hello again people,
I'll have to do an oil change on my new bike soon for the first time. The manual for my Kymco Pulsar only specifies SAE 15W40, API SF. There's a bewildering array of oils of that spec. I'm not sure if any oil with those specs will do, or does it have to be specifically for motorcycle or have other properties? Some of the 15W40s for example seem to match but are labelled as being for diesel engines.
Seb
PostPosted: 20:52 - 30 Apr 2011    Post subject: Reply with quote
Pretty much. Newer oils (ie, higher spec) can cause clutch problems as SF is a pretty old and obsolete standard as far as car oils go. There are a few that are known to often cause problems, such as the Castrol Magnatec.
czakal
PostPosted: 21:01 - 30 Apr 2011    Post subject: Reply with quote
Thanks for the real quick reply. Guess I'll have to buy motorcycle specific stuff and pay the expense. A bit annoying as my manual states it needs a change about every 2000km.
Seb
PostPosted: 21:11 - 30 Apr 2011    Post subject: Reply with quote
Just get Morrisons/Tesco 10w40, your bike isnt going to moan at you... especially since it states every 2000km.
Its £3 for like 2 litres of the stuff, pretty disposable if you ask me. I use it in anything apart from the car.
czakal
PostPosted: 21:47 - 30 Apr 2011    Post subject: Reply with quote
I'd love to do that but hesitated as my bike is pretty new (though it's a cheap one). What oil grade does your manual specify for your bike?
Livefast123
PostPosted: 21:54 - 30 Apr 2011    Post subject: Reply with quote
10w40 and 15w40 are basically the same oils but the 10w is thiner when cold so gives better cold start protection. They both have 40 viscosity when warm.
15w40 used to be a real popular viscosity, nothing much uses it these days as 10w40 has taken over as a multipurpose grade.
You won't do any harm by putting in 10w40
Current ride - Yamaha MT-07
czakal
PostPosted: 22:12 - 30 Apr 2011    Post subject: Reply with quote
Thanks so much for this tip. The savings will really add up, with the frequent oil changes I have to do.
Seb
czakal
PostPosted: 22:15 - 30 Apr 2011    Post subject: Reply with quote
Just one thing though. Do I have to match the API SF specified in my manual? That property doesn't seem so common in the mass market motor oils.
Seb
Livefast123
PostPosted: 22:16 - 30 Apr 2011    Post subject: Reply with quote
Frequent oil changes = Long engine life Thumbs Up
Just make sure you clean the oil strainer to.
weasley
PostPosted: 22:29 - 30 Apr 2011    Post subject: Reply with quote
API SF is obsolete so you won't find any. However, API specs are backwards compatible, so the newer ones are suitable for use in place of the preceding ones.
Livefast123
PostPosted: 22:48 - 30 Apr 2011    Post subject: Reply with quote
Just stick with bog standard morrisons / tesco's 10w40 and you'll be fine Thumbs Up
czakal
PostPosted: 15:10 - 01 May 2011    Post subject: Reply with quote
Hope you don't mind me continuing this topic?
A bit of websearch shows a wide range of opinions on using car oil in bikes. The one specific problem flagged up is that car oil reduces friction too much, which can cause clutch slip as bikes use wet clutches. From the sounds of it though, don't think any of you who use car oil seem to have experienced this. As my 125 is low power I'm a bit less worried but just want to hear of everyone's experience.
Seb
PostPosted: 15:18 - 01 May 2011    Post subject: Reply with quote
Used car oil in bikes loads of times without any problems. Including fully synthetic car oil.
Only time I have had clutch issues with car oil in a bike was after it was tuned quite substantially. It also slipped on new clutch plates and bike specific oil.
In theory the oil specs are backwards compatible but not always. The newer specs do have more friction modifiers. And ironically with the latest ones they are not as effective (the older friction modifiers were not friendly to catalytic converters, and the replacements are not as effective).
Livefast123
PostPosted: 15:26 - 01 May 2011    Post subject: Reply with quote
The only time this will happen is if you buy a oil with friction modifyers like Castrol Magnatec or high spec fully synthetics etc.
I used to run my 125 pit bike on Tesco's bog standard 10w40 for years and never had a problem with it.
Here's a page of bike oils just to give you an idea - https://www.opieoils.co.uk/c-782-10w-40-engine-oil.aspx
Personally on a 125 with frequent changes I would stick to a bog standard 10w40 from the supermarket.
cb1rocket
PostPosted: 19:17 - 01 May 2011    Post subject: Reply with quote
10w 40 for the win, as others have said its a basic bike and basic engine, its not going to cry with 10w 40 in the bike. Don't pay too much attention to the spec, its an obsolete standard so don't worry. Just get asda/tesco/morrison 10w 40 or castrol GTX 10w 40 oil and away you go!
weasley
PostPosted: 19:48 - 01 May 2011    Post subject: Reply with quote
You may be confusing friction modifiers with antiwear additives. The main culprit in terms of catalyst poisoning is ZDDP (zinc dialkyl dithiophosphate) - specifically the phosphorus content. You're right in that ZDDP is the bee's knees of antiwear additives (and good antioxidants too) but their use has had to be reduced to meet catalyst compatibility requirements. Friction modifiers are often organic and will have little or no effect on a cat.
A basic car oil should be OK in a low power bike, but for anything with any poke I would go bike-specific every time. Not only does car oil not always work well in wet clutches, but they are also not designed to put up with gearbox meshing and shear stresses.
PostPosted: 20:25 - 01 May 2011    Post subject: Reply with quote
Start buying your tickets, Shit is about to go down, Kickstart has been challenged by weasley.
Place your bets.... now Laughing
Livefast123
PostPosted: 20:57 - 01 May 2011    Post subject: Reply with quote
I've never had a problem with any of my engines, gearboxes or clutches using car oil. My Chinese pit bike took years of merciless thrashing being run on Tesco 10w40 and never had a problem then I sold it to a mate and it's still going strong.
It may be true if you have a the latest GSYR 84v Turbo but then if you had a Ferarri then you wouldn't run it on Tesco oil....would you Confused
I'm only running my GT250 on Castrol Evo as Opie had it dirt cheap.
PostPosted: 21:14 - 01 May 2011    Post subject: Reply with quote
I use pretty much any 10w40 oil in my bikes. The only time ive bought expensive stuff is when I borrowed G's bike, thats a pretty tuned engine...so needed it.
The Supra, only got the finest oil I could get my mitts on Laughing
czakal
PostPosted: 21:48 - 01 May 2011    Post subject: Reply with quote
I think the way car oil is ok for some bikes (low powered) but not for others (anything else) probably explains why there's so much differing opinion/experience. I'd definitely be safe with car oil with my Kymco Pulsar.
Seb
PostPosted: 23:23 - 01 May 2011    Post subject: Reply with quote
Nope he is right. Problem with me replying in a hurry.
czakal
PostPosted: 01:29 - 08 May 2011    Post subject: Reply with quote
Hello people,
In another twist I found out that 20w50 oil is extremely cheap (£6 for 4.5L)
https://direct.asda.com/Smart-Price-Oil-4.5ltr/001010129,default,pd.html#descriptionSection
But it's probably too different a spec from the 15W40 specified for my bike. I'll stick with the somewhat more expensive 10W40 (the bike manual interestingly states 15W40 only; the warranty manual states 10W40 or 15W40).
Seb
MinhDinh
PostPosted: 06:56 - 08 May 2011    Post subject: Reply with quote
You are still my hero.
Hit the G spot. Wink
PostPosted: 09:28 - 08 May 2011    Post subject: Reply with quote
Shocked Neutral I say we remove "The Oracle" from your name now... thats only for the pro of this forum Wink Laughing
weasley
PostPosted: 10:37 - 08 May 2011    Post subject: Reply with quote
To be fair, I have 19 years' experience in engine oil product development, technical support, marketing and now technical training. There are, in all modesty, few on this forum more knowledgable in oil technology.
However, on the rest of biking, I am an enthusiastic amateur and definitely not out to undermine or usurp any heroes or oracles!
The last post was made 15 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 129.14 Kb
