| dgo1212 |
 dgo1212 Brolly Dolly
 Posted: 22:27 - 28 Apr 2011 Post subject: 2000 R6 carb model cutting out? |
As above, we have an R6 at work belonging to a colleague that keeps cutting out, ussually when warm but sometimes runs longer than others. I have googled the problem and searched on here and still no joy, up to now we have replaced-fuel, fuel filter, air filter, spark plugs and had carbs balanced. Runs mint when first started but after a while cuts out and when we start it again it wont rev, sometimes before 80d/c but at one point ran up to 100d/c, also we noticed a pipe from the airbox and carbs (I think a breather) with a T-piece so far down, one end of the T-piece blocked off (bodged) and the centre of it open (no pipe attached), we blocked the open part of the T-Piece and it run for longer but then cut out after 100dc, also we blew down the open T-piece and it spat fuel out the top of the carbs if this helps identify the pipe I'm talking about? theres no oil in water vice versa or anything to suggest the engine is at fault however the fuel pump does seem to surge at differant rates when the problem starts, any help on this greatly appreciated as the guy has his mod 2 soon and after a month of trying we still haven't been able to sort his bike. Will also add the bike was bought through auction and think this is the reason it went through as it looks like it's been played around with before he got it and has done this since he bought it (didn't know at the time as we only rode it back a very short distance) , Thanks in advance  |
| dgo1212 |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 00:16 - 01 May 2011 Post subject: |
Sounds like a fuelling problem. Carb related issues I suspect.
Does it start with or without choke? Sounds from what you have described like its running really rich.
What colour were the plugs that came out?
Also could be cracked inlet rubbers, but I doubt it as your symptoms don't match that but might be worth checking anyway! ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| dgo1212 |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 09:23 - 01 May 2011 Post subject: |
If the airbox is piped wrong, it'll completely fuck up how the bike runs. check it's all done properly. The T piece you speak of is not bodged.
I'm getting my old R6 back for a few days to do some work on it sometime soon so i'll get a photo of the airbox plumbing for you, or if you're local I could do it for you because i've rebuilt the things enough times.
Other than that, the fuel pump could be fucking up as mine always sounded a constant tone unless i was really low on fuel. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| dgo1212 |
| 0l0dom0l0 |
 Posted: 12:22 - 01 May 2011 Post subject: |
from what you are describing it sounds like the crank case breather has been disconnected.
I'm trying to find a workshop manual to see how it is supposed to be connected. Have you got a haynes manual for it?
I've searched for a while and can't seem to find a service manual so I'd suggest going to get a haynes manual and checking the airbox installation bit and seeing how the t piece should be connected, as this will cause running issues.
Also it does sound like its an excessively rich mixture, I would also remove the Carbs and check that all the needle clips and jet sizes are standard (no dynojet kit fitted etc). Also give them a good clean and check everything is working correctly.
In answer to the OP it is certainly not an electrical related issue.
HTH ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
The last post was made 14 years, 340 days ago. Instead of replying here, would creating a new thread be more useful? |
