Varadero oil smells of petrol
dgo1212
PostPosted: 21:53 - 03 May 2011    Post subject: Varadero oil smells of petrol Reply with quote
Came to change oil on my 125 Varadero today and when I removed the oil cap I got a wiff of fuel, stuck my nose over the hole and had a sniff and sure enough, it stinks of the stuff. If this was the cage I'd be concerned as there would clearly be a major problem, however not sure about the bike, should it smell of petrol, or is there a problem developing? Had no reason to think there was a problem with the engine, there's no oil leaks, no drop in power and no unusual noises if anything it runs perfectly, but the petrol smell has me a little concerned, Karma for any help Thumbs Up
finpos
PostPosted: 23:01 - 03 May 2011    Post subject: Reply with quote
No it shouldn't - almost certainly you have a leaking float valve in your carb and the particular geometry of the bike means it's either overflowing into the inlet manifold and then past the piston rings or into the airbox and down the crankcase breather.
If you want to find out quickly disconnect the fuel pipe at the tank and use a syringe/funnel or similar full of petrol (make sure you don't create a vacuum) instead as a mini-tank and see if the level drops overnight, it's probably a very slow leak that only happens when the bike is stood.
f.
dgo1212
PostPosted: 23:35 - 03 May 2011    Post subject: Reply with quote
f.
Makes perfect sense and may solve my last mystery, I left the bike stood for a couple of month begining of this year, I'd filled the tank prior and didn't start it the whole time it was stood, the day I started to use it again I noticed the fuel wasn't up to the rim, took about 5 litre to fill it back up, i assumed it had evapourated somehow. If it was leaking into the casing the way you explained could it still smell from then?
Also noticed at the time the oil was difficult to check through the window as the oil was a clearer colour than usual, after a couple of days it darkened up again, possibly fuel sat on top?
Wont be able to do the mini-tank test till Saturday night as bike is used for work on weekdays but will give it a go Thumbs Up
Is it potentially a big problem as I plan on selling the bike soon and would rather not have to do too many repairs on it before I do, however I don't want to shaft anyone at the same time so if damage is innevitable I will have it repaired
finpos
PostPosted: 00:02 - 04 May 2011    Post subject: Reply with quote
Pretty much that, then! the fuel won't have mixed into the oil well until the engine churned it up, and I expect the bike started pretty well after it's lay up because you'll have been pumping fuel up the crankcase breather into the airbox and out through the carb making it run somewhat rich until enough got displaced.
You should fix it really - the thinned oil won't be as good a lubricant and will eventually knacker the bore and the bearings.
f.
Ingah
PostPosted: 00:14 - 04 May 2011    Post subject: Reply with quote
It may be a simple case of cleaning the carb and/or fuel tap diaphragm (if it has one).
-- Ingah
dgo1212
PostPosted: 00:23 - 04 May 2011    Post subject: Reply with quote
Yeah started pretty well considering the long lay off and the extremely low temperatures.
Thanks for the advice and will get onto having it repaired asap, don't wanna fix it myself as I'm not a fan of carbs. (in short I'm shit with them and whenever I "fix" them I end up with leaks or bigger problems than I started with Sad )
The last post was made 15 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 49.59 Kb
