BN125 repairs
bn125
PostPosted: 13:52 - 22 Apr 2011    Post subject: BN125 repairs Reply with quote
Anybody know roughly how much labour a garage would charge to get the forks replaced on my kawasaki BN125? I can get hold of the parts myself.
Also the mileage clock doesn't work (the tenths work just the main digits don't), the speedo is fine, is it possible to fix or will i need a new speedo?
Paxovasa
PostPosted: 13:54 - 22 Apr 2011    Post subject: Reply with quote
Normal rate is £40 PH.
I would guesstimate 2 hours.
Edit: Are you replacing the forks are getting them repaired?
bn125
PostPosted: 13:58 - 22 Apr 2011    Post subject: Reply with quote
Replacing them
Paxovasa
PostPosted: 14:18 - 22 Apr 2011    Post subject: Reply with quote
Remove the brake claiper and the front wheel, then loosen the clamps that hold the forks in place, slide them out. Then slide in the new forks, tighten the clamps, reattach front wheel and brake claiper. Should only be 1 hour's labour charge. Thumbs Up
bn125
PostPosted: 23:10 - 03 May 2011    Post subject: Reply with quote
Even though I'm supplying a good pair of forks they wanted to replace the seals and oil - £150 inc labour
So I did it myself which took just an hour.
Thanks for your help.
The last post was made 14 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 41.74 Kb
