What other engines will drop into a CR250 frame?
sandman1976
PostPosted: 18:08 - 03 May 2011    Post subject: What other engines will drop into a CR250 frame? Reply with quote
Basically as the title says, cant afford to do it yet but would be good to be ready armed for when i do Smile
Ta
Teflon-Mike
tl;dr
PostPosted: 23:01 - 03 May 2011    Post subject: Reply with quote
Given a welder, an angle grinder, pipe bender, vice, files, a little tubing, bit of sheet, a bit of know how and a lot of skill.....
Almost anything you facied.... from a C50 engine up to a CBX-6....
hmmmnz
PostPosted: 23:57 - 03 May 2011    Post subject: Reply with quote
pretty much any 2 stroke water cooled motor should go in with out too many hassles, a honda motor will give you the best of the mounts lining up
i beleive the cr500 motor etc is almost a direct swap, but there are expensive
the humans are dead
I kick arse for the lord
sandman1976
PostPosted: 21:17 - 04 May 2011    Post subject: Reply with quote
What about an old YZ250 engine?
Teflon-Mike
tl;dr
PostPosted: 13:49 - 05 May 2011    Post subject: Reply with quote
OK....
Well, 250 single cylinder two stroke, much like what the frame was designed to wrap around..... mounts will all be in the wrong place as like, but filled with weld and re drilled and jiggled... shouldn't be too hard...
But surely rather easier to put a CR lump back in, for a 250cc two stroke single MX motor is what you want in there?!
The last post was made 14 years, 276 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.13 - MySQL Queries: 13 - Page Size: 46.08 Kb
