tzr 125
andyovls28
PostPosted: 09:41 - 04 May 2011    Post subject: tzr 125 Reply with quote
i took the tzr for mot today and it failed on two things 1 the chain was too tight which is a simple fix however it also failed as the back break light was flickering and it flashes the same time as the indicator if they are on at the same time
am i right in thinking that it needs a new battery as it seems to be drawing power away for each indicator flash.
would also like to ask if any body knows anything to clean the tank as emptied 14 pounds worth of fuel out tonight and threw it away as it was brown and full off rust and crap so wondered if anyone knew of any possible additives
cheers andy
hazza
PostPosted: 10:08 - 04 May 2011    Post subject: Reply with quote
If you rev the bike up with the indicator and brake light on does it cure the problem? if so its not getting enough juice which would suggest the battery, however the 6v electrics on my old bike (rxs 100) used to do this all the time and that never failed.....
*edit* also there are tank sealants that will stop the rust but if it isnt too bad then why not try an in-line fuel filter for about a pound?
Regards
Harry
andyovls28
PostPosted: 10:32 - 04 May 2011    Post subject: Reply with quote
cheers for that ever thought about an inline filter however when i rev it up it goes dimmer
PostPosted: 10:38 - 04 May 2011    Post subject: Reply with quote
Revving and going dimmer suggests that it isn't charging. Check the voltage over the battery as you rev the engine.
Other possibility for the lights is a bad earth to the rear lights. For a test you can run an extra earth back to it and see if that cures it.
andyovls28
PostPosted: 10:52 - 04 May 2011    Post subject: Reply with quote
thanks will try get it done before retest im buying a new battery anyway as this one is about 2 years old
PostPosted: 11:03 - 04 May 2011    Post subject: Reply with quote
If it isn't charging then the battery will probably not help that much.
The last post was made 15 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 47.76 Kb
