| hazza |
 hazza World Chat Champion
| Moo. |
 Moo. World Chat Champion
 Posted: 11:01 - 04 May 2011 Post subject: |
Shouldn't be too hard, the main thing is to get the engine running, give it a good service, change the oil and filter and maybe new plugs. Probably put a new air filter in, or give it a wash if its a sponge. Clear out the carbs and balance if it has two. Other then that go over the bike and check all the bearings, chain and sprockets, tyres may need replacing from standing so long Obviously wash the tank out and give it fresh fuel.
The only real difference between a 2 stroke and 4 stroke is a seperate oil compartment, which is why servicing the oil filter and changing the oil is important, the rest you should be able to handle all a good learning curve ____________________ A2 Passed 18/6/10 |
| hazza |
 Posted: 11:21 - 04 May 2011 Post subject: |
well thats what i thought I cant help but tinker with things anyway and now ive finished my dissertation (*sigh*) ive got plenty of time on my hands. Id really like to further my knowledge of four strokes. Hopefully it will be a nice little commuter for me once sorted.
*edit* what is the method of balancing the carbs?
Thanks for any replies
REgards
Harry ____________________ 3 Honda NC50's(Sold)-->'72 Puch Maxi S (Sold, want it back!)--> '90 Yamaha RXS 100 (Stolen)--> '87 Honda Cub 90(Sold) --> '95 Kawasaki Eliminator (Sold) --> '98 Bandit 600 (Sold) -->'07 SV650S (Current) |
| jimspeed |
 jimspeed World Chat Champion
 Posted: 21:33 - 04 May 2011 Post subject: |
I've got one and had it for just over a year now (almost sounds like the one I bought to be honest)
fairly basic and simple to work on except the carbs, I was going to remove mine to clean them out but it looks like that is an engine out job so I gave it a few tanks of fuel cleaner instead and it runs ok. bit rattley on idle but mine goes quiet once the clutch is in and 1st gear selected.
The bits I have bought for mine have been cheap and ER5 rear shocks fit if you want to stiffen the ride up a bit (they were cheaper too lol) the only bugbear is the odd tyre sizes they use.
fairly quick and high powered for a 250 (mine is 34bhp most 250's seem to be 20 or so).  ____________________ Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?" |
| Frost |
 Frost World Chat Champion
| hazza |
| Robby |
 Robby Dirty Old Man
 Posted: 06:47 - 05 May 2011 Post subject: |
It is has been standing a long time and you have a lot of time on your hands, I would take it apart and give it a frame up rebuild. Not necessary, but the sort of thing I do for fun and it means you can clean and grease every bearing. Minimal cost, lots of benefit. Also means you can scrape off all of the rust and paint over the exposed areas.
If it has been standing with the fuel tank empty then it is likely to have rusted, so you want to get rid of the rust before using it. Rust will get into your carbs, even past a fuel filter, and clog up the idle jet. Phosphoric acid is the best method I know to sort out a rusted tank, just be sure to remove the fuel tap and plug the hole with a cork or something because phosphoric tends to eat rubber.
Apart from that, usual big service. Change the oil and filter, then do it again after 500 miles. New plugs and air filter, check of swingarm and steering head bearings, quite possibly new tyres, new brake fluid, fit a fuel filter, give it a really good clean and wax, possibly new fork seals. Get rid of all the rust.
It will cost a few quid to recommission, being left standing is no good for bikes. |
| hazza |
| hazza |
The last post was made 14 years, 277 days ago. Instead of replying here, would creating a new thread be more useful? |
