Head removal on a Honda CG/XR? (update:head gasket replaced)
kingsknight
PostPosted: 17:32 - 06 May 2011    Post subject: Head removal on a Honda CG/XR? (update:head gasket replaced) Reply with quote
my head gasket is leaking oil on my XR, How hard is it to remove the head of the engine to replace the leaking gasket? Anyone done this on a CG or XR before?
Got the replacement gasket, just need to know how to take the head off as I'v never done this before.
Thanks for any help guys!
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
pepperami
PostPosted: 17:37 - 06 May 2011    Post subject: Reply with quote
Sorry I cant help as I`ve never done it either Sad .
However when you get the advice and start to do it , post up LOTS of pics and give us a write up please Thumbs Up
Frost
PostPosted: 17:40 - 06 May 2011    Post subject: Reply with quote
It's all just undoing bolts which is really easy, except for the cam chain assuming it has one, which it may or may not depending on the year of the bike. You might need a chain riveter to split the chain. Putting it all back together is just the reverse, but you must tighten the bolts on the head in a cross pattern to squash it down evenly
kingsknight
PostPosted: 18:12 - 06 May 2011    Post subject: Reply with quote
its a push rod engine so it should be a VERY simple job..... I hope! I will add lots of before and after photos for sure! I just need to know how to take the head off! there seems to only have on bolt holding the top part of the engine on, on the right hand side!
kingsknight
PostPosted: 18:17 - 06 May 2011    Post subject: Reply with quote
thanks a lot mate, I'v JUST worked this out by looking at this https://cgi.ebay.co.uk/Honda-CG125-CG-125-2006-Head-Camshaft-/110683334693?pt=UK_Motorcycle_Parts&hash=item19c53da825#ht_500wt_1156
lol
Will I need to take off the tank to get the head off?Thanks rob for replying!
kingsknight
PostPosted: 18:22 - 06 May 2011    Post subject: Reply with quote
I take it that it is a Cylinder Head Gasket which I need to replace?
kingsknight
PostPosted: 19:39 - 10 May 2011    Post subject: Reply with quote
Right I did it and it went really well! Push rod engines are so bloody simple to work on. I ended up having to take the complete head off because on of the push rods slipped off its bottom holder when I was putting it back together.
took me about 3 hours all in all because you have to strip everything off on a XR.
Put it all together, went for a 20mile run and yay no leaks and the engine sounds sweet as ever!
I will upload the photos i took later, thanks for your help rob!
pepperami
PostPosted: 19:53 - 10 May 2011    Post subject: Reply with quote
Write up and photos please Thumbs Up
Keep it nice and simple with a lot of explanation for those of us who would like to learn from your exploits Smile
kingsknight
PostPosted: 20:27 - 10 May 2011    Post subject: Reply with quote
did ya do the valve clearances when you put it back together?
yeah mate they have needed doing for well over a year now lol
I will give a nice write up. I didnt take a lot of photos because i kept getting oil over my phone but I know exactly what to do now though!
truslack
PostPosted: 00:21 - 11 May 2011    Post subject: Reply with quote
What year of XR is it? Could have sworn most were cam chains Confused
truslack
PostPosted: 08:33 - 11 May 2011    Post subject: Reply with quote
rob yarrr wrote:
isn't it the XL with cam chains?
Sorry, yes you're right, I always get the 2 confused.
pepperami
PostPosted: 18:01 - 11 May 2011    Post subject: Reply with quote
NO NO NO! go back and do it again ..... this time with pictures Thumbs Up
Pepperami wants to see ! Laughing
kingsknight
PostPosted: 18:35 - 11 May 2011    Post subject: Reply with quote
Here are the photos I took!
The leak
https://a3.sphotos.ak.fbcdn.net/hphotos-ak-snc6/224281_10150186494948622_500588621_6904339_2210047_n.jpg
Stripping down the bike
https://a2.sphotos.ak.fbcdn.net/hphotos-ak-snc6/224396_10150186495048622_500588621_6904340_4856456_n.jpg
Strip EVERYTHING off from around the engine
https://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash4/228211_10150186495153622_500588621_6904342_2480509_n.jpg
Strip off the top of the head and the rocker unit thing
https://a7.sphotos.ak.fbcdn.net/hphotos-ak-snc6/225586_10150186495233622_500588621_6904345_6790699_n.jpg
The bits look like this
https://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash4/228371_10150186495303622_500588621_6904346_6307259_n.jpg
Remove the carb and then remove the head
https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/227521_10150186495458622_500588621_6904350_236073_n.jpg
Remove the old gasket and clean up both the upper and lower head with a old rag or something to remove all the oil and crap.
https://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash4/225406_10150186495553622_500588621_6904352_7576366_n.jpg
Put it all back together with the new gasket and go for a nice long run!
https://a2.sphotos.ak.fbcdn.net/hphotos-ak-snc6/227416_10150186494848622_500588621_6904335_102629_n.jpg
Cool
Simple guide:
Strip down bike including the top engine mount which is bolted to the frame by to bolts which are covered by 2 rubber protectors
undo 3 bolts to remove the top cover
undo 3 more bolts which keep the rocker thing in place. Remember to hold onto the 2 push rods as you remove the rocker.
undo 4 more main bolts which are under the rocker unit
Slide the head up off holders
Clean both parts of the heads
replace gasket
put the bitch back together, just remember when putting the rods back in that the rods go into the bottom part of the engine at an angle!
Simples!
Just remember I'v never done any form of engine work like this before now and I found it pretty simple. It is ALMOST as simple as a 2 stroke engine as you cannot mess the timing up.
Any questions I will do my best to answer them! Hope this helps anyone else who done needs this done.
I was quoted £120+ vat for a shop to do this job AND i would of been without the bike for 3 weeks!
Cost me.... £10 for the gasket and 3 hours of my time!
50miles since i done the job and its not leaked at all Very Happy
kingsknight
PostPosted: 18:45 - 11 May 2011    Post subject: Reply with quote
Rob, what are the cables leading the the carb? I broke off one of the connectors leading to the carb. The bike still runs like it did before so it cant be too important can it?
kingsknight
PostPosted: 18:53 - 11 May 2011    Post subject: Reply with quote
yeah i thought that, may have running problems in the winter?
kingsknight
PostPosted: 19:05 - 11 May 2011    Post subject: Reply with quote
its the part which bolts onto the carb, snapped clean off from the rubber, i cant repair it!
That would be amazing if you could do that for me mate!!!
The last post was made 15 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 136.58 Kb
