Can anyone help?
nc30 chick
PostPosted: 10:21 - 19 Aug 2004    Post subject: Can anyone help? Reply with quote
Can anyone recommend a good mobile mechanic or good garage in the Bracknell area (or close surrounding areas), my car is playing up big time and i need to get it sorted. Not really sure whats wrong with it but someone said it could possibly be the head gasket.
Not sure if a ford garage would be more expensive.
Many thanks
Em
Odie
PostPosted: 11:02 - 19 Aug 2004    Post subject: Reply with quote
What exactly is the problem with the car that makes you think its the head gasket that is gone?
Do you have oil/scum in the radiator or do you have what looks like mayonnaise in the rocker box (lift the oil filler cap and look inside)
If you have either of these things then your head gasket could have gone, the best thing to do is get a compression check done to see if there is a lower compression on one or more cylinders.
Hope this helps
You are so ugly when you were born the doctor said "I?m gonna drop it, if it falls is a rat, if it flies is a bat."
PostPosted: 11:10 - 19 Aug 2004    Post subject: Reply with quote
Kev lives in Bracknell and works at George Whites in Ascot and should be able to give you some help. Send him a PM. Thumbs Up
nc30 chick
It was a friend that suggested it, he is a truck mechanic.
She doesnt always have much power in her through the lower gears, she goes ok from 70+ but below that she is spluttering and bunny hopping around. We are losing water and we dont know where, she is overheating. When idle the revs go up and down sometimes.
Im not mechanically minded so i havent got a clue.
Odie
PostPosted: 11:20 - 19 Aug 2004    Post subject: Reply with quote
You say that you are loosing water, is there a puddle under the car when you go to pull away?
If you don't have a puddle under the car you may have the head gasket gone on a water way, with it not liking to pull away very well it could be into the inlet manifold.
check to see if you have any water coming out the exhaust pipe and check the rocker box filler cap for mayonnaise,
these are all signs of a possible blown head gasket.
nc30 chick
PostPosted: 11:25 - 19 Aug 2004    Post subject: Reply with quote
Thanks Odie, There is no obvious water leak and no puddles so i will get hubby to check what you said tonight, have just sent a PM to Kev to see if he can help.
Many thanks
Odie
PostPosted: 11:30 - 19 Aug 2004    Post subject: Reply with quote
Thats ok, glad to have been of assistance, sorry i don't live in your area, would have done the job for you, hope you get it sorted soon
The last post was made 22 years, 56 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.35 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 51.96 Kb
