Yamaha Aerox moped mayhem preparation
Gazdaman
I did a trackday!!!
PostPosted: 14:39 - 10 May 2011    Post subject: Yamaha Aerox moped mayhem preparation Reply with quote
As the title, this bike was bought for £60 to transform for any moped mayhem type events running this year. Main one in mind is the 'supermotopedathon' run at RAF Wittering as that's what I've entered last year.
So this is how I picked the bike up from a kindly BCF member
https://www.gaz-racing.co.uk/images/vehicle_1275.JPG
and quickly began stripping it apart
https://www.gaz-racing.co.uk/images/vehicle_1278.JPG
To start with my team-mate and I had massive plans for USD off-road forks and rear suspension, 12" wheels to increase tyre choice massively and knobbly tyres.
We were planning on a pitbike front end, which would mean pitbike Yokes, forks, wheel, axle, spacers, caliper and bars. And probably getting a new stem machined to suit the frame.
So we bought a 12" wheel from a Speedfight as it looked like the right PCD and should bolt straight on.
https://www.gaz-racing.co.uk/images/vehicle_1290.JPG
Of course it didn't.
https://www.gaz-racing.co.uk/images/vehicle_1355.JPG
https://www.gaz-racing.co.uk/images/vehicle_1360.JPG
Then I wasted a good part of my life designing and fabbing an adapter to fit the new wheel. Once I'd made the prototype I realised it would push the wheel off centre by about 2 inches which would make handling simply horrible.
So we decided to abandon the 12" wheel, and the posh front end. We were losing sight of the aim of the competition. So we decided to keep it cheap and work with what we had instead.
https://www.gaz-racing.co.uk/images/vehicle_1302.JPG
We'd picked up a bargainous race exhaust off eBay and I set about VHT painting it.
https://www.gaz-racing.co.uk/images/vehicle_1446.JPG
Then it was time for a top end rebuild. The bike has 10k miles on it, and no idea if it's ever been done. From the state of the old barrel I'd suspect not. We went with stock displacement to stay within the rules.
https://www.gaz-racing.co.uk/images/vehicle_1452.JPG
And the lump got a lick of paint.
https://www.gaz-racing.co.uk/images/vehicle_1454.JPG
Then it was time for the frame to go on a diet.
https://www.gaz-racing.co.uk/images/vehicle_1460.JPG
and the pile of bits for powder coating has grown
https://www.gaz-racing.co.uk/images/vehicle_1464.JPG
I'm planning on keeping the bike road legal (without any bodywork) so once this is all over I can get either a daylight MOT, or lash up a very minimal headlight and go from there.
I've found a good local powder coater that does it all nice and cheaply, so I figure why not.
Only thing we need to do before coating is to brace up the frame like so
https://www.gaz-racing.co.uk/images/vehicle_1465.JPG
Then it's reassembly. There are a few new bearings and seals and things to go on as its reassembled, but nothing too major.
The stock fuel tank sits behind the rider's seat, it's not massive, and it's a fair bit of weight in the wrong place. So I'm planning on relocating a small go-kart type fuel tank into the under-seat storage space. It'll bring the weight central and low, and it'll mean I can ditch the standard fuel tank. (Which would be useful since I killed the fuel cap). So I'm on the lookout for a go-kart or generator fuel tank that'll fit in a 9" x 8.5" gap, but must be gravity fed unlike a lot of go-kart tanks.
Then add number boards, hand guards, some sort of crash protection and some 13" knobbly tyres (which do exist).
Then run it in, play with jetting, mess with the rollers and clutch springs etc and race it!
Gaz
SpannerMonkey
PostPosted: 14:46 - 11 May 2011    Post subject: Reply with quote
I wanna join on on this mopedathon! Pleaseeee?!
My bike? A YX140 powered one-off Monkey Bike, something a little different!
speedy
PostPosted: 17:10 - 11 May 2011    Post subject: Reply with quote
hey nice looking project..if the original forks are in good condition then keep them as the stock rox forks are very good and it sounds like you'll waste a lot of time and money on usd's may be it'd be worth doing a couple track days or something with stock forks on to see how they feel
also have you thought about getting a tank made to fit in the seat or is that too much weight
whats the rules on the engine spec i.e do you have to keep to a certain cc or a certain level of tuning
if its just a cc limit why not split the cases and do some flowing and possibly port the barrel a little then go for a bigger carb as the standard is very small iirc
what exhaust is that?
Gazdaman
I did a trackday!!!
PostPosted: 18:42 - 11 May 2011    Post subject: Reply with quote
The exhaust is a Technigas. But really we only got it because it was the cheapest on eBay.
Capacity limit is 50cc for 2 strokes.
Supermotopedathon hasn't been announced yet, but the key is to find a crap ped and get going!
The stock forks aren't in great condition, but they're definitely salvagable. I am planning a trackday at the local go-kart track once this is done. I've got a two bike trailer, and I'll need to take my pitbike, so I may aswell run both.
I'm not too worried about weight for a fuel tank, but having one made would be added cost. I'm hoping I can just get one suitable that'll fit. It's very spacious under the seat, with a 9" x 8.5" gap that must have about 8" height.
I had thought about flowing etc, and in an ideal world, with infinite time, I would. But I've not even split the cases, the engine runs and runs quite well. So I've decided to leave alone for now. Long term I'll pick up another engine and do a proper job on it, replacing the main bearings (maybe the crank too) then powder coating the cases etc. That would be the ideal opportunity to flow and port and polish etc.
The only tuning we're going to be doing on this is the race exhaust, maybe a free flowing air filter and jetted to suit.
Gaz
SpannerMonkey
PostPosted: 19:22 - 11 May 2011    Post subject: Reply with quote
Awww Sad Mines four stroke
Gazdaman
I did a trackday!!!
PostPosted: 19:50 - 11 May 2011    Post subject: Reply with quote
It's 90cc limit for 4 strokes.
Really you need something cheap and shit. The cheaper and shitter the better.
Gaz
Nope.
PostPosted: 22:49 - 11 May 2011    Post subject: Reply with quote
Wanted to do one of these for a while. Just need to find a crap moped first!
Are these usually charity events or somthing?
dextersaurus
PostPosted: 00:18 - 12 May 2011    Post subject: Reply with quote
should get the frame done bright yellow/pink, and get a leopard print seat cover for it.
Fantastic work so far. i'd love to get involved in one of these Mr. Green
Dunc
Gazdaman
I did a trackday!!!
PostPosted: 12:22 - 14 May 2011    Post subject: Reply with quote
Dunc
I intend on giving the powder coater free reign and just saying "Do it all in some bright disgusting colour". Then it'll be a nice surprise when I pick it up.
Although I do have a hankering for a bright orange.
I'm not a fan of leopard print seats covers etc though. That'll likely stay black.
gaz
retrobiker
PostPosted: 12:46 - 14 May 2011    Post subject: Reply with quote
looks a fun project... will be watching this one
dextersaurus
PostPosted: 13:26 - 14 May 2011    Post subject: Reply with quote
But where's the fun in that? Mr. Green Laughing
Gazdaman
I did a trackday!!!
PostPosted: 13:45 - 14 May 2011    Post subject: Reply with quote
Because we're talking race 'peds boi, this aint no joke!
(Loosely based on a Fast and Furious quote for those playing at home).
gaz
Shaft
PostPosted: 23:48 - 14 May 2011    Post subject: Reply with quote
Gaz
While searching around for ideas for my own MM project, I found this:
https://www.mypurerush.com/category-show.php?catID=93&parent_id=92
Any good?
I suspect the capacity might be a tad too small, but can't be far off.
Incidentally, is there anywhere I can find the rules for these events, as I've also got some ideas about things like fuel tanks, but I don't want to find out I've contravened any regs, after I've done the mods.
Gazdaman
I did a trackday!!!
PostPosted: 14:45 - 16 May 2011    Post subject: Reply with quote
There aren't really any rules. Just think about it in the spirit of the competition and it's common sense.
No pit bikes, or small MX bikes. It's got to be a proper ped really. Then it's a capacity limit (some allow different capacities depending if it's manual or auto gearbox).
I have seen those fuel tanks, I don't think the shape would be right for the hole.
Gaz
Gazdaman
I did a trackday!!!
PostPosted: 10:53 - 20 May 2011    Post subject: Reply with quote
https://www.gaz-racing.co.uk/images/vehicle_1477.JPG
Bracing box section cut and offered up
https://www.gaz-racing.co.uk/images/vehicle_1478.JPG
Welded
https://www.gaz-racing.co.uk/images/vehicle_1479.JPG
Cross brace added
https://www.gaz-racing.co.uk/images/vehicle_1481.JPG
https://www.gaz-racing.co.uk/images/vehicle_1482.JPG
Ready for powder coat!
Gaz
speedy
PostPosted: 12:31 - 20 May 2011    Post subject: Reply with quote
Thumbs Up Very Happy
projects like this make me smile I hope to do similar some day
Gazdaman
I did a trackday!!!
PostPosted: 11:32 - 23 May 2011    Post subject: Reply with quote
Frame, handlebars, both wheels and two engine covers were dropped off at the powder coaters this morning to be collected on the 16th of next month.
It's all going a very BCF orange.
Gaz
MarkJ
PostPosted: 11:46 - 23 May 2011    Post subject: Reply with quote
Gaz, how much are you paying for powdercoating all that lot? Are they also doing the sandblasting and did you mask off all the threads for them?
Gazdaman
I did a trackday!!!
PostPosted: 12:14 - 23 May 2011    Post subject: Reply with quote
It's £100, I chucked a mountainbike frame in to be done too. They do all the shotblasting and masking.
They did my ke175 chassis, so I know they're of a standard.
Gaz
MarkJ
PostPosted: 12:41 - 23 May 2011    Post subject: Reply with quote
Christ, that sounds cheap, all the ones with websites that specifically do bikes say that just a frame can be £100-150! Is this just a normal powdercoaters that does fencing etc.?
Gazdaman
I did a trackday!!!
PostPosted: 12:50 - 23 May 2011    Post subject: Reply with quote
It is cheap, I think they mostly do industrial stuff like skips and railings etc, but they do advertise doing bike/kart/kit car chassis.
Their customer relations isn't great. Both times they've done stuff for me they've not got in contact to say that the parts are done, and when I've contacted them to enquire they've been like "Oh yeah, they've been done for AGES!".
But they do a decent job, and it's cheap, so I'll keep using them, if my biggest grumble is I have to phone them, then so be it.
This is them: https://www.newtechpowder.co.uk/
Gaz
aerox12
PostPosted: 12:15 - 29 May 2011    Post subject: help Reply with quote
ive just fitted a 70cc kit on my 08 aerox, the timing is all wrong and it keep cutting out! it wont start first time! feels asif somthing is holding it back!! HELP
and could anyone tell what the two gold things are coming from the top of the cylinder head by the thermostat???
help
Gazdaman
I did a trackday!!!
PostPosted: 14:50 - 29 May 2011    Post subject: Re: help Reply with quote
Make your own thread, preferably in the workshop forum rather than hijack mine.
And I don't know which 'gold things' you mean on the head.
Gaz
Gazdaman
I did a trackday!!!
PostPosted: 13:49 - 16 Jun 2011    Post subject: Reply with quote
Chassis' back from the powder coaters!
Gaz
MarkJ
PostPosted: 14:55 - 16 Jun 2011    Post subject: Reply with quote
All that for £100, looks a good job too Thumbs Up
The last post was made 14 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 135.88 Kb
