125cc more power
phoenixluckyb...
PostPosted: 06:54 - 13 May 2011    Post subject: 125cc more power Reply with quote
hi i own a modest china made 125cc. the engine is built exactly as the Honda CG125. is slightly heavier than the CG however due to the bodywork.
i'm thinking of getting more power outta this little baby somehow. what i'm aiming at is something that wont require mechanical modifications in the engine itself. something that goes on and comes off.(is that even possible?)(this is mainly so that i can sell it off stock if i need to someday)
so i was wondering if introducing a small turbocharger might do the trick? if so, how can i achieve that? and what exactly will i need to do?
as you might have realized i don't know much about mechanical modifications and this might even seem funny to most people. but any help i can get is much appreciated!
Cheerio! Very Happy
*~Phoenix~*
PostPosted: 07:04 - 13 May 2011    Post subject: Re: 125cc more power Reply with quote
Cheerio! Very Happy
Do not attempt it Laughing There is a bloody small turbo for chinese bikes floating around somewhere... but its a few hundred quid, not worth it as you can do your test with that money and get a much bigger bike Laughing
PostPosted: 07:14 - 13 May 2011    Post subject: Reply with quote
Depending on how much you want to spend...
https://cgi.ebay.co.uk/New-cg150-cylinder-block-Replacement-cg125-Enhance-/270735304366
or
https://cgi.ebay.co.uk/NEW-CG150cc-Chinese-engine-replacement-156FM1-2-/390300695704
Although you said you don't want to make engine modifications, this won't be any harder than trying to fit a supercharger.
ThoughtContro...
PostPosted: 07:17 - 13 May 2011    Post subject: Reply with quote
It's a Chinese CG copy. They're not the most reliable of bikes as far as reputation goes, due to inferior materials and quality control compared to the major Japanese manufacturers.
If you really want more speed use it to pass your test. You can sit an A2 test on a 125, which will allow you to ride any bike, as long as it's restricted to 33bhp, for a period of 2 years. Often these restrictors mysteriously fall out allowing riders access to the bike's full power, tho this is entirely at their own risk, and the power restriction expires in 2 years anyway. A larger bike is the best route to more power, albeit it'll cost you more in insurance, fuel and road tax than a 125.
You could play about with the sprocket sizes, trading off acceleration for a possible minor increase in top end. Playing about attempting to extract power in other ways will likely result in the engines early demise. Given that it's Chinese that may be alot quicker than you might want, and before you get much chance to enjoy your extra burst of a few mph extra speed.
Your call, but I wouldn't bother.
Prize cunt
phoenixluckyb...
PostPosted: 07:31 - 13 May 2011    Post subject: Re: 125cc more power Reply with quote
i'm living in pakistan so the test is not a problem as we can ride any bikes or cars on a single license(which i already hav Very Happy).
considering i'm willing to get the small turbo for whatever price... wat exactly will i need to do, to install it n get going??
i'd love to get a bigger bike but it isn't really an option for me right now with my finances Sad
*~Phoenix~*
phoenixluckyb...
PostPosted: 07:32 - 13 May 2011    Post subject: Reply with quote
Thanks ThoughtControl and The Shaggy D.A. for your input! Very Happy much appreciated!
*~Phoenix~*
PostPosted: 07:57 - 13 May 2011    Post subject: Reply with quote
If you don't have the money for a bigger bike, I wouldn't waste it trying to wring more out of that engine. It's sturdy and reliable (yes, even in Chinese-made guise) but it's never going to be a rocketship.
If you really do want to spend on it, then consider a 150cc barrel and piston swap.
bennell09
PostPosted: 10:02 - 13 May 2011    Post subject: Reply with quote
the 150 block or getting your current one polished + ported also changing gear ratio and try optimizing your carb jetting on a dyno to get a little extra Thumbs Up
PostPosted: 10:08 - 13 May 2011    Post subject: Re: 125cc more power Reply with quote
Why not just get a more powerful second hand bike, then?
A performance modification that is 'easily removable' (ride the original bike) and I expect will save you money over all.
PostPosted: 11:04 - 13 May 2011    Post subject: Reply with quote
Not sure where you have seen a turbo suitable. There are loads of cheap electrical fans sold by various people on Ebay as turbos, but they will be useless at best (and at worst fail and dump debris into the engine).
Finding a real turbo for such a small engine will be difficult (well, just about impossible), and even if you do find one fitting it and setting it up will be a lot of work. New exhaust and intake for a start.
dangerousdave
PostPosted: 19:46 - 13 May 2011    Post subject: Reply with quote
For an the easiest power increase change the exhaust, and air filter for sportier versions.
Filter: Get a K&N for it. You may need to modify it slightly to fit the CG airbox.
Exhaust: Not sure if sports exhausts were made for this bike - but one may fit from CB125 etc. Failing that, modify the standard exhaust for more airflow (drill out the end). If you know a welder then cut the silencer off and have a sports muffler welded on.
If you want much more power then there is no substitute for a bigger engine. I hear the Honda XL185 engine fits.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
Teflon-Mike
tl;dr
PostPosted: 21:27 - 13 May 2011    Post subject: Reply with quote
nowhere.elysium wrote:
Oh god. I've just found what appears to be a proper turbo and EFI kit (well, two seperate kits) for 125cc engines. They claim to work on the GY6 clones.
https://www.chinese-parts-canada.com/images/IHI_RHB31_Buggy_go-kart_GY6_turbo_turbocharger.jpg
On thread turbo-ing a single cylinder 125
It gace me some very silly ideas.... like a twin turbo CB125 Super Dream! Laughing
kramdra
PostPosted: 21:39 - 13 May 2011    Post subject: Reply with quote
since your in pakistan, you can probably do what ever you want to it. If I had that opportunity over here, it would be an engine swap, 250cc or so.
also a used engine would be far cheaper!
Except on my cg125 that would be suicidal becuase the brakes are so bad.
Teflon-Mike
tl;dr
PostPosted: 22:12 - 13 May 2011    Post subject: Reply with quote
I think the problem in Pakistan is lack of bigger bikes and stringent import restrictions.....
PostPosted: 22:24 - 13 May 2011    Post subject: Reply with quote
Afraid I would take the claims for that turbo with a large pinch of salt. Can't see a commercial use for it which leaves it being a special made for cheap tiny 125s, and as such I would be rather cynical about the quality of it.
Teflon-Mike
tl;dr
PostPosted: 22:38 - 13 May 2011    Post subject: Reply with quote
Forget whether it actually WORKS... just think about the playground bragging rights! Laughing
PostPosted: 23:02 - 13 May 2011    Post subject: Reply with quote
Bragging rights for having to push it home after the RAC decided you had already called them out too many times?
heehaw
PostPosted: 15:17 - 14 May 2011    Post subject: Reply with quote
Hmmmmm?????? Thinking
Its important, otherwise it wouldn't be there.
Retro Rider Bicycles: CB125TDC, CBR400RR, BSA Bantam.
dangerousdave
PostPosted: 16:58 - 14 May 2011    Post subject: Reply with quote
be interested to hear how you get on with the turbo . . .
phoenixluckyb...
PostPosted: 06:49 - 16 May 2011    Post subject: Reply with quote
wow! thankyou all for your suggestions!
now check this out! the bike i have is a china copy of the HONDA deluxe 125 model(picture attached) available here in pak... the diffrnc is front disc brakes in the deluxe against drum in mine...
now a lucky friend of mine had an uncle who moved away n gave him his 125 deluxe... n this friend claims that the deluxe has some kinda in-built turbo mechanisms that takes the ENGINE air outlet(exhaust) and sends it back to the air filter to be compressed by some fan... i rode the deluxe and it runs super sweet!
now i asked this friend if i could open up the air filters n carbs on the deluxe to check out how it works... and mebe somehow implement that in my bike. he agreed... I hope we can do it soon! and if it can be ported to my bike... well that would solve this issue... and i can move on to thinking up something else to do with ma ride Very Happy
wish me luck people! Very Happy
*~Phoenix~*
Tristan.
PostPosted: 09:25 - 16 May 2011    Post subject: Reply with quote
You'll find thats there for emissions purposes, it draws clean air in with the exhaust gasses. No power gain.
PostPosted: 10:22 - 16 May 2011    Post subject: Reply with quote
As above. If an exhaust gas recirculation system then probably there to lower combustion temperatures and reduce NOx emissions.
The last post was made 15 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 131.34 Kb
