| MikeyBrown |
 MikeyBrown Scooby Slapper
 Posted: 20:53 - 13 May 2011 Post subject: 1991 GPZ500S Camchain Tensioner Removal? |
Hi,
I'm not sure if this has already been posted somewhere on the forum, and my internet is horrendous on an Ipad, but I would just like to know how I'd go about removing the camchain tensioner from my GPZ500? Is it as simple as just undoing the bolts and removing it from the engine or is more complicated than that?
I am currently waiting for a Haynes manual thats taken over a week to deliver but I just need to remove the tensioner so I can take it to a local shop to order a new one (the shop owner says he needs to see it, to check if he has any decent priced New-Old-Stock in his storeroom). Also, is it possible to rebuild/service the damaged tensioner or is replacement the best/cheapest option?
Thanks in advance
Mike ____________________ Past Bikes: '97 CG125, '91 GPZ500S, '01 FZS600, '07 S/Triple, '99 ZX9R, '82 GP125, '83 GP100, '03 SV1000S, '98 ZX6R
Current Bike: '07 FZ1N
Trackdays: Darley Moor - 15/6/12, Donington - 28/8/12 |
| Kickstart |
 Kickstart The Oracle
 Posted: 21:11 - 13 May 2011 Post subject: |
Yes you can just remove it like that, although make VERY certain you do not crank the engine with it out. Probably best to set the engine to tdc.
However you can't just lob it back in. It is a sprung ratchet, so when you remove it the spring will extend pusher the tensioner out to its full extent. And the ratchet will stop you pushing it back in. Normally remove the bolt from the end, remove the spring, reset the tensioner and put it in place, then replace the spring and bolt (and turn the engine over a few times by hand ).
There is not really that much to wear in one. The tensioner teeth shouldn't move enough to wear while the spring is only there to move the tensioner once in a blue moon to take up slack.
| MikeyBrown |
 Posted: 21:30 - 13 May 2011 Post subject: |
| Kickstart wrote: | Hi
Keith |
Thanks yet again Keith :L I wont be putting it back in until I have the Haynes manual, I just want to get the new part.
If they don't wear that often, what could be causing a rattle/click at idle? At idle, it rattle/clicks and my uncle reckons it's the CCT. When you rev the bike, under load or not, the click disappears at around 3000 rpm :S ____________________ Past Bikes: '97 CG125, '91 GPZ500S, '01 FZS600, '07 S/Triple, '99 ZX9R, '82 GP125, '83 GP100, '03 SV1000S, '98 ZX6R
| Kickstart |
 Posted: 21:52 - 13 May 2011 Post subject: |
The cam chains do wear and as they wear the tensioner needs to take up that slack. Just that they seem to get worse at it with age. Possibly the spring getting old combined with it having further to move to take up the tension.
Also on the GPZ there is a primary drive chain taking drive from the crank to the clutch. This can also wear with age but has no tensioner. And can thus slap around like a worn cam chain.
| MikeyBrown |
 Posted: 22:05 - 13 May 2011 Post subject: |
Keith |
I'm a little confused as to what I should do. What would you advise? Adjust the tensioner, replace the tensioner, replace the primary drive chain, replace the cam chain or just leave everything and see if it gets any worse or...?
I do appreciate your time to answer my rambling questions by the way so thanks
| Kickstart |
 Posted: 22:26 - 13 May 2011 Post subject: |
How long is a piece of string?
They were well known for needing new cam chains years ago.These days people just seem to replace the tensioner rather than the cam chain.
The cam chain is possible to replace with the engine in the frame (use a rivet link one), but the I think the primary drive chain would need a full engine strip.
Personally, they are fairly rattly engines anyway. I would just leave it unless really noisy.
| MikeyBrown |
 Posted: 22:42 - 13 May 2011 Post subject: |
Keith |
Hmmmmmm :/ I might just leave it for a few miles on the road and see if it gets any louder/worse. If it doesn't, then I shall just leave it I think. If it aint broke (or obviously broken in this case ) then dont fix it I suppose :L might price up some of those parts though, just to get an idea in case I do need to replace one (probably in a couple of hundred miles - its only done 17.8k miles now) ____________________ Past Bikes: '97 CG125, '91 GPZ500S, '01 FZS600, '07 S/Triple, '99 ZX9R, '82 GP125, '83 GP100, '03 SV1000S, '98 ZX6R
| dextersaurus |
 dextersaurus World Chat Champion
| temeluchus |
| Dazbo666 |
 Dazbo666 World Chat Champion
 Posted: 07:43 - 14 May 2011 Post subject: |
@ the OP
Yes you can just take the tensioner out, but as already mentioned, do not crank the engine with it removed.
You'll need a little manual dexterity and the correct procedure to reinstall the new one, but it's more than possible as minor a DIY job
The bike would benefit from balancing the carbs, but also be aware that GPZ engines tend to sound quite rattly compared to a lot of other bikes
(I had a '91 GPZ previously and learned loads about riding and maintenance with that bike ) ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
| MikeyBrown |
 Posted: 12:20 - 14 May 2011 Post subject: |
Hi,
Thanks for the responses, I'll have a check over the carbs and maybe see about balancing them and to be honest, I might remove the tensioner and just have a poke around with it, see if I can adjust it and check it all over.
And it's done 17600 miles, but it's been, by the looks of it, dry stored for the last 12-18 months. I have serviced it recently (but not valve clearances or camchain tension) and checked everything over to make sure it's roadworthy of course
Failing that, could it just be a typical noisy engine then? I've heard a few people say they sound they're going to explode on idle ahaha other than this rattle/jingle/click, the engine sounds pretty sweet given that it's 20 this year!  ____________________ Past Bikes: '97 CG125, '91 GPZ500S, '01 FZS600, '07 S/Triple, '99 ZX9R, '82 GP125, '83 GP100, '03 SV1000S, '98 ZX6R
The last post was made 15 years, 136 days ago. Instead of replying here, would creating a new thread be more useful? |
