Restricting speed?
GREENI3
PostPosted: 19:40 - 13 May 2011    Post subject: Restricting speed? Reply with quote
Every time I get to 37 mph, it sort of cuts the power/acceleration (the engine stays on though) for a second then returns back to normal, but keeps doing the same thing every time it gets to 37 mph. Sort of like a juddering motion.
I know it's a 50cc moped and your first assumptions are probably a cdi restriction or something along those lines, but it's only started happening recently.
Before, it would go as fast as it could. It managed 45 mph down a hill, but if I tried going down that same hill now, it will go no further than 37.
Any ideas what it might be?
Thanks, Thumbs Up
Redoko
PostPosted: 19:47 - 13 May 2011    Post subject: Re: Restricting speed? Reply with quote
Thanks, Thumbs Up
I know this isn't what you want to hear, but.
Does it really matter? It's only a moped. Give it some slack. Confused
cb1rocket
PostPosted: 21:58 - 13 May 2011    Post subject: Reply with quote
it appears you have done the CDI but not the washer in the variator....? Confused
Nope.
PostPosted: 23:23 - 13 May 2011    Post subject: Reply with quote
The AY50 has three restrictions:
1) The exhaust (Washers in the manifold)
2) The Washer in the variator
3) A rev limiter in the CDI
It sounds to me like you have hit the Rev limiter in the CDI. You'll need to replace it with a third party one. Malossi do one that works well.
GREENI3
PostPosted: 23:51 - 13 May 2011    Post subject: Reply with quote
Everything is completely standard, no de-restriction or anything.
But it would go as fast as it could possibly go. No rev limiting.
It only started doing it since the spark plug cap came off whilst I was out on a ride a month ago.
It was running perfectly until then. Sad
The last post was made 15 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 45.23 Kb
