| monty16v |
 monty16v Two Stroke Sniffer
| sandman1976 |
 sandman1976 Nova Slayer
| skatefreak |
 skatefreak World Chat Champion
| monty16v |
| skatefreak |
 Posted: 16:29 - 13 May 2011 Post subject: |
Hey,
funny that, I'm a bike guy who just bought a car thats turning into a project :p haha.
I'm sure you'll be fine though.
PM me if you need a manual for the bike, can be useful at times.
The powervalue is just underneath the tank towards the front right, quiet obvious when you look under the tank, this opens and closes to increase the exhaust port when required.
From 0-2k rpm it should be open and from 2k- 7.5k should be closed, beond that it should stay open. This helps get the most linear power curve out of the engine.
When you go to the bike and start up, rev up a little past 2k and see if the servo moves. If its not moving on the bottom end then it wont be working on the top end.
It seems people think its cool to cut the cables to the servo and pin the servo closed, it gives the bike a much more punchier delivery but does no favours through mid range.
It also sounds like you could be running a little rich on the oil, if you take the service pannel off the right, front mid pannel, you will then get some access to the engine.
Looking for a suitable image I came across a little tutorial on this which covers it quiet nicely (the 150 and 125 are the same).
So, R/C valve okay, oil pump checked out due to your thoughts on the plug...
I'm not to sure what else it could be but will have a think. Maybe compression test, clean the carbs and check the air filter whilst your going over the oil pump?
Best regards
-Jvr
Ps, with this in mind i have found my NSR a little hesitant to pull through the power band for the first time each ride lately. Warmed up as usual etc. Will give her a good servicing, carb, clutch (been putting off for a while) stator, reg, battery (I will nail that leccy spook!) de-coke head and exhaust, reeds, clean air filter, sparkie, front disk, pads, brake fluid (maybe caliper seals), fork seals and fluid... I have most of the parts here anywho lol. |
| dangerousdave |
 dangerousdave Traffic Copper
| Truzo |
 Truzo Nova Slayer
| skatefreak |
| monty16v |
| monty16v |
| dangerousdave |
| monty16v |
| leepick |
 leepick Scooby Slapper
| monty16v |
| monty16v |
| monty16v |
| Stowelly |
 Stowelly Traffic Copper
| monty16v |
| monty16v |
| monty16v |
| skatefreak |
The last post was made 15 years, 59 days ago. Instead of replying here, would creating a new thread be more useful? |
