Honda XL125V Varadero + Aftermarket Exhaust = Slower bike?
chrisjpartrid...
PostPosted: 15:39 - 15 May 2011    Post subject: Honda XL125V Varadero + Aftermarket Exhaust = Slower bike? Reply with quote
I have an '02 Varadero 125 which I use for commuting. The bike is overall is what I would describe as good condition though has started to suffer from a rusting mild steel exhaust - a common problem on these bikes.
It started to blow recently and after assessing the pipes the other week I found that the downpipes where rusted but repairable but the rear section (silencer/can and the pipe leading from it) were rusted through and not worth saving.
My plan became to replace the lot with stainless pipes, but looking at the cost of new parts I decided to spread this out a little.
I have since welded up the downpipes for now and discarded the rear in favour a second hand Devil can from eBay.
The can is it pretty good condition and now fitted I have no exhaust blows anywhere in the system.
I have left the "DB killer" in as it just sounds silly for such a small engine to make the amount of noise it does with it out.
https://i1129.photobucket.com/albums/m511/chrisjpartridge/Bikes/Varadero%20125/15052011308.jpg
Now here's the problem - The bike is noticably much slower!
I should point out I'm not expecting much here: The bike is a 125 and I'm in no way trying to tune it here, mearly trying to change to more robust parts.
When the standard exhaust was good the bike would happily sit at 60 MPH on levelish A roads, and with it blowing it started to struggle but would get there in the end.
Now though it struggles past 50!!
Though I have some theories I'm not too sure where to go from here so was wondering if anyone else has had similar issues.
CaNsA
PostPosted: 17:11 - 15 May 2011    Post subject: Reply with quote
is it Fuel injected or carbd?
Shaft
PostPosted: 18:43 - 15 May 2011    Post subject: Reply with quote
Should be carbs, don't think they injected it until much later.
Sounds like it's either fuelling wrong or there's a back pressure problem; is the can meant for that bike?
chrisjpartrid...
PostPosted: 19:18 - 15 May 2011    Post subject: Reply with quote
It runs on twin carbs - they changed to injection in 2007.
The exhaust is ment for this bike and the fit and quality seems pretty good (I've seen enough rubbish in the past to appreciate this!),
The bike ran fine right up until the change and the carbs have not been touched at all.
Back pressure was one of my theories though I'm not sure how it applies on an engine like this.
A good example of ruining back pressure to me is when you see all the dick heads who putting massive exhausts on small hatchbacks, removing the back pressure and in effect de-tuning their engines.
As the bike perfomed better than this with a blowing exhaust though I dismissed it.
Another thought that was carb related was that perhaps the carbs would need to be altered or up-jetted to suit this; however again I didn't thing so A) as it ran better with a blowing exhaust and B) I've not read about this being nessasary on a 125.
Having taken the bike out again this afternoon I would descibe the problem now as a distinct lack of torque and the bike refusing to want to rev into the top quarter of the range.
JackDaniels
PostPosted: 20:21 - 15 May 2011    Post subject: Reply with quote
Id say you should need to upjet a little, can you take your spark plugs out and post up a pic ?
THEORY TEST - PASSED! - 02-08-11 CBT Passed - 09-08-10 MOD 1 - 09-08-2011 - MOD 2 - 28-09-2011
2006 Yamaha JOGRR>2010 Yamaha Ybr>1995 Honda CB400 Superfour >2005 Honda hornet>1999 Suzuki Bandit 1200 > 2002 BMW R1150GS > 2013 Tiger Sport 1050 > 2007 GSXR 1000 > 2005 GS500E
Teflon-Mike
tl;dr
PostPosted: 21:21 - 15 May 2011    Post subject: Reply with quote
Running with a blowing header.... not good.
First thing have you done the basic maintenence?
Tappets, cam chain(s), etc.
Hole in header usually means nil back pressure, & lean mixture.
May run very well for a while, but often at the cost of burned out exhaust valves or distorted pistons etc.
Could be, that the added oomph of fcuked header masked problem it causes inside engine.
Fixing header now shows up problem.
Next welded header.... how so done? have you choked the pipe pilling hole with weld, or did you plate over?
chrisjpartrid...
PostPosted: 22:18 - 15 May 2011    Post subject: Reply with quote
The pipe has a plate welded over it.
Engine has done just over 9,000 miles - was on 8,100 when I bought it and the exhaust only failed about 200 miles ago and didn't seem severe at first, infact the holes it had were tiny as it'd just started to go, hence being able to repair it.
Tappets are fine and if it was a valve issue you'd know!
There is no rattle at all from the engine nor is there any smoke.
Teflon-Mike
tl;dr
PostPosted: 22:24 - 15 May 2011    Post subject: Reply with quote
Would you?
How Idea
dangerousdave
PostPosted: 03:13 - 16 May 2011    Post subject: Reply with quote
How is the performance with the db killer removed ?
Will it get to 60 then ?
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
HoggyF
PostPosted: 12:21 - 16 May 2011    Post subject: Reply with quote
Why not check with Devil if they recomend re-jetting or if its supposed to be a direct swap?
PostPosted: 12:45 - 16 May 2011    Post subject: Reply with quote
Another request to get your (plug) tips out for the lads.
Moxey
PostPosted: 13:49 - 16 May 2011    Post subject: Reply with quote
Slip on cans normally don't require re-jetting unless specified. Sounds like the cause of the issue is a lack of back pressure if the bike was running fine before try removing the DB killer
what you talking about?!? they sound beautiful! Razz
Failing that there may be a clog in the exhaust pipe from the welding you did or maybe something else. seems to be the exhaust fumes are having difficulty escaping due to blockage or something or other.
prawny1
PostPosted: 20:11 - 17 May 2011    Post subject: Reply with quote
The fact that this pipe comes with a db killer would indicate it is a generic straight through pipe with a link pipe designed for it to fit the varadaro, most of the time it's only pipes with proper deflective baffles that you can get away without rejetting.
I would suggest trying to lift the slide needles in the carbs by lowering the circlip this will richen the wide open throttle fueling slightly if this help (which it will) then you neede to rejet,
sometimes if a bike is running lean you can try pulling the choke on when it starts to run out of puff if it picks up then again you know you need to rejet.
If you are keeping the standard air filter you usualy don't need to upjett too much, one size on the slow jet and 2 or 3 sizes on the main.
hellkat wrote:
ClockworkJesu...
PostPosted: 21:27 - 17 May 2011    Post subject: Reply with quote
Only problem with changing exhausts ect. is you ultimately change the design of the engine - and the variables the engine was tuned to run to!
I'd probably jump up a few jet sizes, as lean engines will burn themselves out; so its always better to run richer than leaner;
and besides; if it runs too rich you can always lean it out via the carburettor settings. So a rejet is a pretty safe change, unless you can't spare the £6 or so.
chrisjpartrid...
PostPosted: 21:28 - 17 May 2011    Post subject: Reply with quote
Update:
Had the pipes off today and checked them out only to find a large lump of carbon trapped inside the small pipe.
I've not put it back together yet but can assume that must have been blocking it.
It's always the simple things that cause the most head scratching!
Perhaps I should point out that the engine in the bike is not the origional as I bought the bike last winter with a seized engine and swapped it out so I'm blaming it on that!
I'm not going to bother putting it all back again though as I've just ordered some nice stainless downpipes for it - no more rot to worry about.
Thanks for all the suggestions though guys; I'll come up with a tougher puzzle next time!
PostPosted: 10:17 - 18 May 2011    Post subject: Reply with quote
You've done a plug chop, right? Confused
chrisjpartrid...
PostPosted: 23:10 - 30 May 2011    Post subject: Reply with quote
UPDATE:
For anyone that's interested I have the bike all sorted now and can share some wisdom...
I have splashed out some more of my hard earned cash on some Motad stainless downpipes, stainless clamps, new seals, etc. and done the whole lot properly - No more repairs; just all new stuff that'll last and won't rust.
There's only so long you can patch things up for anyway.
Overall the Motad pipes are actually quite good for what they are though a little pricy. The quality is good but the little clamp the include doesn't fit!
The end result was a lot better performing and as it wasn't full of carbon and holes actually sounds a lot better and more even.
I was however still having performance issues which I have now traced to a sticking choke cable.
Basically it presses in but not fully unless you take a look at it and jiggle it back; not something you can notice or attend to while riding.
I plan to either just replace this or am considering making a remote cable to run up to the handlebars - something I'm supprised Honda didn't think to include on such a bike.
The whole thing runs smooth now and manages to get past 60 on the straights once more.
Next to get my 400 to run smoother as well!
temeluchus
PostPosted: 04:18 - 31 May 2011    Post subject: Reply with quote
The next person to say back pressure will be shot.
There is a gap of 231 days between these two posts...
Fladdem
PostPosted: 21:35 - 17 Jan 2012    Post subject: Reply with quote
I like the hand guards, did you fit them yourself? If, so was it difficult? Can you give me a make and model, please? I am thinking of playing about with my Varadero because my dad wants it afterwards, the 850's great, it's just you get better fuel economy in a spaceship. Just toying with ideas at the moment really. Sorry for not creating a new thread but that picture just looks so good.
The last post was made 14 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.43 - MySQL Queries: 13 - Page Size: 109.54 Kb
