| will108 |
 will108 Derestricted Danger
 ..... Quote Me Happy
| Nope. |
 Nope. World Chat Champion
 Posted: 21:31 - 15 May 2011 Post subject: |
Right, when you fit an open air filter to a two stoke you are changing the fuel/air mixture AND reducing back pressure, this means that you will effectively be running with too much air and not enough fuel as well as reducing compression. This really isn't good for the engine and drastically reduces performance. If you want to run with an open air filter you will have to upjet 10-12% if not more. This will drastically increase your fuel consumption. However, there is absolutely no point to you running an open filter. The open filters are designed for those with Big bore (>70cc) kits, larger carbs, sports exhausts and just generally tuned up engines. Basically, you've just wasted money on decreasing performance. You will probably find that even if you do upjet you will have lost a fair bit of performance.
Bung the air filter on the Variator air ducting. They look reasonable there and it wont affect performance.
This will explain the science of an airbox in better terms then I can here:
https://www.scootershack.co.uk/airboxguide.html
So, in summary, ditch the open air filter and stick with your stock airbox. Job done. ____________________ Former: Derbi GP1 50, Sachs XTC 125, Suzuki GSXR 400 GK73A, Kawasaki ZX7R, Suzuki DR250, Yamaha RD350
Current: 2011 Yamaha XT660Z Ténéré, 2003 Yamaha YZR-R1 5PW (In Build), 2009 Kawasaki ZZR1400 |
| heehaw |
 heehaw Nova Slayer
| will108 |
| Teflon-Mike |
| InspectaBike |
 InspectaBike Derestricted Danger
 Posted: 10:32 - 16 May 2011 Post subject: |
Don't agree I am afraid. You certainly don't have to change the exhaust to suit the filter to avoid losing power. But the gains from a change in filter will be tiny and the possible losses from getting the jetting wrong can easily be greater.
The exhaust doesn't care about the air filter, and it works from pressure waves dependent on rpm rather than any specific level of pressure.
The last post was made 15 years, 124 days ago. Instead of replying here, would creating a new thread be more useful? |
