| N cee thirty |
 N cee thirty Banned
| Benson_JV |
 Benson_JV World Chat Champion
 Posted: 00:04 - 14 May 2011 Post subject: |
Fookin nice.  ____________________ Willson - "If you go out on that CBR600 in the winter, you're going to do more miles on your side than on your wheels."
Previous Bikes: '96 Bandit 600, '96 GPz305 |
| N cee thirty |
 N cee thirty Banned
 Posted: 13:29 - 16 May 2011 Post subject: |
started to take it apart
https://i825.photobucket.com/albums/zz176/robyarr/DSC00913.jpg
toke 10 mins to get to this stage,small bikes ftw
the seat base doesn't look too bad from what i've heard,as they rust like a mofo
https://i825.photobucket.com/albums/zz176/robyarr/DSC00914.jpg
what could i do to stop it rusting any further ? ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| blurredman |
 Posted: 13:55 - 16 May 2011 Post subject: |
Not a bad bike you've got there.
Hammerite. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| TimNorwich |
 TimNorwich Traffic Copper
 Posted: 13:56 - 16 May 2011 Post subject: |
To stop it rusting further you can coat it in Hammerite paint, followed by some ACF-50, shouldn't be too bad after that since it's not an area that gets particularly wet.  ____________________ Speedshite 50cc > Honda XR125L > Kawasaki GPZ 500 S > 02 Honda Hornet > 05 Honda CG125 winter hack > 04 Kawasaki ER-5 > 99 Honda Hornet 600 > Kawasaki GPZ 500 S > 99 Honda Hornet 600 > 05 Honda CBR600F > 01 Honda Hornet |
| N cee thirty |
 N cee thirty Banned
 Posted: 13:59 - 16 May 2011 Post subject: |
arr right,thanks peeps  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
| blurredman |
 Posted: 14:12 - 16 May 2011 Post subject: |
Good thing with Hammerite is that you don't have to sand it all, just the bits which are loose (inc paint+metal) until you get to the solid metal. Then just cover the thing in it  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| Serendipity |
 Serendipity World Chat Champion
 Posted: 21:46 - 16 May 2011 Post subject: |
Are you planning to also replace the seat cover? When I repaired the seat on mine I stripped it down and threw away the cover. It was ripped beyond redemption and I was fed up of getting a wet arse from rain soaking into the foam. Trying to undo the bolts holding on the pillion strap led to both studs snapping so I left that off too. Never had a pillion use it anyway. I also had one of the teeny bolts keeping the metal trim on snap during removal. Still worked with one less.
Then a quick rub down and several coats of Hammerite on the metal pan, top and bottom. Left that to dry for a week or two then rebuilt the seat. I don’t know if they’re all the same design but mine was just a case of putting the foam in place and hooking the new cover over little teeth all the way around the seat. No staples. Bolted the trim back on and jobs a goodun! A bit of a wrinkle near the back of the pillion, but I'm not fussed.
https://i221.photobucket.com/albums/dd227/serendipity_uk/RXS100/IMGP1985a.jpg
https://i221.photobucket.com/albums/dd227/serendipity_uk/RXS100/IMGP2025a.jpg ____________________ 2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| N cee thirty |
 N cee thirty Banned
 Posted: 21:55 - 16 May 2011 Post subject: |
yerr i'm probably going to replace it,one on ebay atm
yours looks awesome though,i might take that strap off aswell as you said
thanks for the write up  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
| 27cows |
 27cows World Chat Champion
 Posted: 17:04 - 21 May 2011 Post subject: |
Don't know how I managed to miss an RXS thread - must be slipping
Are you sure the carb is beyond help? It's possible to use longer screws with a nut on the end if the threads are stripped.
The level of rust on the main base doesn't always correspond with the number of seat cover spikes that are missing. Those are the main thing you need to preserve and stop from rusting/snapping. But it's possible to get creative with self tapping screws in order to have something to fit the cover to if you really have to (I really have to ).
First thing that catches my eye with your RX is the pipe. It's all shiny The tank looks in bloody decent nick too. Tank and pipe alone are worth £100 or more, so I think you can rest easy that you got a good bargain. ____________________ The RXS100: vehicle of choice for Chuck Norris |
| N cee thirty |
 N cee thirty Banned
 Posted: 20:59 - 21 May 2011 Post subject: |
lol the pipes cleaner than my cg's and ats only a year old
the carbs fine now,but when i have some money i will probably replace the snapped mixture screw
this is my next problem
https://i825.photobucket.com/albums/zz176/robyarr/DSC00917.jpg
annoyingly all the original philips head screws are still in and ruined,i got one out but there's still the other 2 in,whats the easiet way to get them out now ? cut a groove in for a flat head ?
cheers ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
| TUG |
 TUG World Chat Champion
| MarkJ |
 MarkJ World Chat Champion
| N cee thirty |
 N cee thirty Banned
| Teflon-Mike |
| N cee thirty |
 N cee thirty Banned
| 27cows |
 Posted: 09:24 - 22 May 2011 Post subject: |
To remove buggered engine case screws you just need one large hammer and one old flat head screwdriver. Hammer a bit of a slot on one side of screw, jar loose with said hammer. Job done
Bung some stainless socket caps in there in place of crap cross heads. ____________________ The RXS100: vehicle of choice for Chuck Norris |
| steven_191 |
 steven_191 Nearly there...
| Serendipity |
 Posted: 10:22 - 22 May 2011 Post subject: |
I bought a fancy battery powered impact driver a while ago after years of using an old bog standard impact screwdriver like this.
Conclusion: the power tool is good for getting small and not too stuck stuff out, especially in hard to reach places. However it’s also better at mashing up screw heads and hopeless at moving really seized objects.
On the other hand, my 18 year old Draper impact screwdriver, in combination with a rubber mallet is, quite simply, pure win. Worth every penny.  ____________________ 2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| Teflon-Mike |
| N cee thirty |
 N cee thirty Banned
| Teflon-Mike |
 Posted: 13:36 - 22 May 2011 Post subject: |
| rob yarrr wrote: | mike you think a 18 year olds going to have a whole selection of tools ? |
No but I would have thought you could find a HAMMER lying around some where
And something 'punch like'... like an old NAILl!
To deform the head of the screw back into the hole to give whatever you try twisting it with a bit of extra purchase!
Tip was a bit of 'simple' basic, no specialist tools, assistance to help solve your problem without having to get hi-tech on it and use a power drill or E-Z Shear or anything.....
CAVE MAN technology, BASH IT!
Incredibly, if you notice I have remarkeably FEW specialist tools, or a fully kited workshop! I probably have poorer facilities than a lot of 17 year olds given a corner of the garage!
Impact driver, though, WAS one of the first specialist tools I aquired... it was a 15th Birthday Present from My uncle, who reckoned 'If y' gonna kip wirkin on owd bykz, y'll fyne thiz 'elpful' He was right!
So back on track, stubborn screw, over eager mechanic...
1/ Do you have a hammer?
2/ Do you have something 'punch like' say a big old nail?
3/ Do you have an impact driver, or is that something you are waiting on the postman for? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| The Artist |
 The Artist Super Spammer
| Teflon-Mike |
| N cee thirty |
 N cee thirty Banned
The last post was made 15 years, 107 days ago. Instead of replying here, would creating a new thread be more useful? |
