Forged v Cast pistons
Old Git Racing
PostPosted: 12:46 - 16 May 2011    Post subject: Forged v Cast pistons Reply with quote
Anyone give me some pros and cons of forged v cast pistons in a 2 stroke?
OGR
Nexus Icon
PostPosted: 13:12 - 16 May 2011    Post subject: Reply with quote
Forged are stronger. Cast are cheaper.
That's pretty much it, tbh.
Forged pistons have an irregular grain structure, which makes them more strong in all directions. Cast pistons have a regular grain structure meaning they will have inherent weakness and stress raisers.
Forged parts are formed using immense pressure to push the red-hot metal into the desired form. Cast parts are moulded using molten metal.
Greetings from Shitsville!
Willson
PostPosted: 13:31 - 16 May 2011    Post subject: Reply with quote
Cast means that molten metal has been poured into a dye and allowed to set.
Forged means that red hot metal has been bashed into shape. Therefore, stronger and much heavier.
Benson: Wouldn't life be easier if we were all turtles?
Me: Pig on bread = The way forward.
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold
Nexus Icon
PostPosted: 13:36 - 16 May 2011    Post subject: Reply with quote
Well, I dunno about them being heavier. That rather depends on whether they're made out of the same material. Forging and casting doesn't drastically alter the density of the material, only the way the grain structure lines up in the part.
Willson
PostPosted: 13:43 - 16 May 2011    Post subject: Reply with quote
Forged metal is denser, you've essentially pushed more metal into the same amount of space.
Edit: Forging removes most irregularities and voids that can be left behind by casting.
If they're the same metal then yes the forged version would be heavier.
Nexus Icon
PostPosted: 13:52 - 16 May 2011    Post subject: Reply with quote
Hmmmm, only if it's a sh*t piece of casting. There shouldn't be any voids, Willson.
Frost
PostPosted: 14:45 - 16 May 2011    Post subject: Reply with quote
Denser material doesn't mean the piston is heavier. It being denser and stronger means less material will be used therefore making it lighter.
PostPosted: 15:00 - 16 May 2011    Post subject: Reply with quote
Lets assume this is true, and that cast pistons would have air bubbles in or something... A well designed forged piston would have thinner sidewalls etc and therefore be stronger, and weigh the same as cast,
Glenben92
PostPosted: 16:33 - 16 May 2011    Post subject: Reply with quote
Confused it still has to fill the same area. So if it's denser than it'll take more material to fill the same cubed area, therefore it'd be heavier because there's more material.
(marginally anyway)
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
PostPosted: 16:41 - 16 May 2011    Post subject: Reply with quote
(marginally anyway)
Thats assuming the dies used for cast and forged pistons are identical....
PostPosted: 16:44 - 16 May 2011    Post subject: Reply with quote
If I can get back on topic a bit:
I can't honestly see the point in forged pistons in a 350 powervalve unless you plan to fit Banshee tuning stuff to it. I can't think that you'll see any benefit of using forged pistons until you get the thing up to 100bhp+
I suspect this is probably a question for Stan Stephens rather than us lot though. Collectively we know a bit, but he's probably forgotten more than we'll ever know.
Old Git Racing
PostPosted: 17:00 - 16 May 2011    Post subject: Reply with quote
Thanks for the replies Thumbs Up
Have already got the pistons. They are going in a tuned YPVS, nothing like 100bhp though. Having had pistons fail before it sounds like these will be more durable if not a little OTT.
Thanks,
OGR
Frost
PostPosted: 17:48 - 16 May 2011    Post subject: Reply with quote
Surely having lighter pistons is a part of getting extra power out of the engine?
PostPosted: 18:27 - 16 May 2011    Post subject: Reply with quote
Thanks,
OGR
The main thing holding back a YPVS Is the ignition system. If you've got a 31k then the sky is the limit, although piston life is very short - perhaps forged pistons would help this, but its normally the rings that suffer. If you've got a 1WT then the revs are limited by the ignition and to a lesser extent the carbs. Stan told me that I should put a ball bearing in the power jets on my 1WT and increase the mains to match the original 31k Jetting. Apparently though 31k's rarely made their warranty period before blowing pistons!!
CaPo
PostPosted: 18:56 - 16 May 2011    Post subject: Reply with quote
I dunno about 2 strokes, but a disadvantage of forged pistons on cars is they need to fit slightly loose when cold as they expand more than cast. This means slightly reduced compression, more oil burning and poor running on cold starts. Fine once warmed up though.
Had: NS125R
Got: GPZ500s, '02 R6
The last post was made 15 years, 153 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 86.99 Kb
