weak battery
czakal
PostPosted: 20:21 - 16 May 2011    Post subject: weak battery Reply with quote
I had a scare this morning as my bike didn't start, and I didn't know how to use the kickstart (this is the only bike I ever used that had one...). I only got it working again when I got back this evening. Is it any cause for alarm if the battery goes a bit weak, or does it happen from time to time even with healthy batteries?
Seb
Nexus Icon
PostPosted: 20:24 - 16 May 2011    Post subject: Re: weak battery Reply with quote
Seb
Eh?
Greetings from Shitsville!
czakal
PostPosted: 20:32 - 16 May 2011    Post subject: Reply with quote
It sounds stupid but I never used one before, and I was panicking a bit as I was getting late to work. I didn't realise I had to kick it much harder (it felt like the kick lever was stuck, but I didn't know I had to just kick it harder...). Stupid but true.
Seb
waffles
PostPosted: 20:33 - 16 May 2011    Post subject: Reply with quote
Batteries run themselves down if there is anything on your bike that flashes or beeps when the ignition is off. If you don't run your bike in a while the battery should be OK for a while unless its on its way out. Easy way to check is to get it drop tested.
Also - kickstarting a bike is easy peasy, gently push down until you feel some resistance then back to the top and give it the beans.
czakal
PostPosted: 20:37 - 16 May 2011    Post subject: Reply with quote
SO it is pretty easy when I found out on returning this evening...
I don't think there's anything draining the power when the ignition is off. All the lights go out. I did recently have to fix the spring that connects the rear brake lever to the brake light switch, but even if I did something wrong there I can't really see how that can drain the battery, if all the lights go out when the ignition is turned off. At least it's good to know I have the kickstart as backup.
Seb
von1papen
PostPosted: 20:41 - 16 May 2011    Post subject: Reply with quote
You have a kickstart and yet you choose to use electric? Real men kick their machines into action Razz
(Not that I have much choice......)
Nexus Icon
PostPosted: 20:43 - 16 May 2011    Post subject: Reply with quote
Seb
I see. A healthy fear of breaking things is not a bad trait, I guess. I imagined you staring at it wondering what to do with it.
Once the bike's off nothing should be draining the battery, assuming it isn't fitted with a digital clock - and, even so, that would be a tiny draw, so you have to consider that the battery is on it's way to being fubar.
How long was it sat between running fine and not starting?
czakal
It did feel a lot more satisfying than the electric start I have to say. More importantly it's a huge convenience on a budget commuter, as I need it to start every morning.
Seb
waffles
PostPosted: 20:49 - 16 May 2011    Post subject: Reply with quote
Did you ride your bike over most of the winter? Cos really cold temperatures absolutely muller batteries. The ex boyfriend found that out the expensive way with his aeroplane, after it sat in a freezing cold hanger for three months it was completely shot and nearly £200 for a new one.
czakal
PostPosted: 22:00 - 16 May 2011    Post subject: Reply with quote
I only had it for 1 month. 1 previous owner, did 10000 km in a year so probably used it year round. Winter riding didn't give me similar problems in my last bike.
Seb
The last post was made 15 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 62.59 Kb
