Suzuki GZ125 oil and filter change
FirebladeRuss
PostPosted: 14:51 - 17 May 2011    Post subject: Suzuki GZ125 oil and filter change Reply with quote
Hey guys and girls
Thought I'd change the oil filter and oil this evening, as I'm not sure when it was done last with the previous owner - and basic service is always something I've done on my cars when I get first get them.
The manual I found talks about replacing the o-rings on the filter (the manual is for a GZ250, so maybe that's why?) - yet the new filter doesn't come with any o-rings?
I assume the whole process is pretty straight forward? Any pointers for a bike-mechnic noob?
Twitter is for people who can't STFU even when they're by themselves
DrDonnyBrago
PostPosted: 15:02 - 17 May 2011    Post subject: Re: Suzuki GZ125 oil and filter change Reply with quote
RussGZ wrote:
Hey guys and girls
Oil filters normally have the O ring as part of the filter.
Look at the open part, should see a black rubber circle on it. You need to put a small dab of oil on that ring before you fit it to help it seal.
https://www.renault4.co.uk/technical/oil-filter.jpg
Other than that follow the manual, is very simple Thumbs Up .
Tips:
Warm up the bike well first, don't drop the sump plug into the oil pan, the oil can be hot so don;'t burn yourself, place something on the ground to catch spills, remove the old filter using a tool if you have one (chain type ones are my favourite, can just stab a screwdriver through it and use that to turn it though), check the oil level a few times after it has been filled (including after running it for a bit), use a new crush washer, put the filter on hand tight only and DO NOT OVER TIGHTEN THE SUMP PLUG!!!!
The Artist
PostPosted: 15:16 - 17 May 2011    Post subject: Reply with quote
I am pretty sure the o ring is between the oil filter cover and the engine. Doesn't need replacing unless damaged/leaking. Be careful not to pinch it when replacing oil filter cover.
FirebladeRuss
PostPosted: 15:17 - 17 May 2011    Post subject: Reply with quote
My oil filter is a pissy little thing, I discovered today when I bought one Laughing Nothing at all like the one pictured above (which looks the same as a car one).
Mine looks like this:
https://motorcycleproducts.co.uk/catalogue/filter-suzuki-gz125-199800-p-144432.html
FirebladeRuss
PostPosted: 15:18 - 17 May 2011    Post subject: Reply with quote
Ah, good stuff - thanks The Artist.
I was hoping that might be the case.
DrDonnyBrago
PostPosted: 15:26 - 17 May 2011    Post subject: Reply with quote
Ah, I thought there might be something unusual with it but took a guess.
Filter aside, very simple mate - get the oil out, seal it up and get the oil back in.
FirebladeRuss
PostPosted: 15:33 - 17 May 2011    Post subject: Reply with quote
Sweet. Thanks guys Thumbs Up
gypsypunk
PostPosted: 13:40 - 12 Aug 2011    Post subject: Reply with quote
hi there i have the suzuki service manual for gz125 and the oil filter does indeed have o rings that need replaced with every oil change .......they are in the housing of the oil cover cap and inside the case that holds the oil filter so they are not fitted to the filter but the parts that hold the filter in place............this is the case for every model as my manual covers 1998 x reg - k6 2006 models
i am in the process of changing my oil on my gz125 but the window is black and dosent clear once ridden to show the oil level
so it need's cleaning a bit of a pisser.
because when i fill up with oil i know i put the right amount in 950 ml with new filter and 800ml without changing filter
but if i cant get it clean it will bug me
The last post was made 15 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 56.73 Kb
