50cc Geely cut out problem...
savage1987
PostPosted: 13:34 - 19 May 2011    Post subject: 50cc Geely cut out problem... Reply with quote
Hi, I have a 50cc Geely moped 06 plate which i bought last week..
It starts up great off kick start and electric..
After about 10 seconds the moped cuts out on idle..
Also when i brake it cuts out...
I adjusted the throttle screw for higher revs but it still cuts out...
Does anyone know what could cause it to cut out?...
Also does anyone have any pictures of the engine/carb/tubes and wires as i have a few tubes that are not connecting to anything...
Any help would be great..
Thanks...
Nope.
PostPosted: 22:12 - 19 May 2011    Post subject: Reply with quote
I swear to god I answer this question every sodding week! Why cant you people use the search bar or look back a few threads...
Anyway, With regards to your idling problem, it could be that your carb is gummed up. Strip the carb down and clean out all the 'varnish' in the bowl with some carb cleaner, a cloth and some elbow grease. Then remove the Main jet, spray some carb cleaner in and then blast it out with compressed air to clear it out.
Re-assemble the carb and see if it sorts the problem. With regards to the braking and cutting out, does it cut out even if you apply the front brake? If so then its probably a wiring fault like a short somewhere. Check all the connections to the break lights.
savage1987
PostPosted: 22:23 - 19 May 2011    Post subject: Reply with quote
I was told it could be the throttle cable as it looks like it has stretched quite a bit that could be causing it to cut out...It is really slack...
And it doesn't look like its for that moped...
And yes it cuts out when i press the front brake...Not all the time though...
Nope.
PostPosted: 22:30 - 19 May 2011    Post subject: Reply with quote
As I say, probably a short in the loom.
If your not happy with the throttle cable then change it, but it shouldn't cause it too cut out at idle I shouldn't think.
savage1987
PostPosted: 22:33 - 19 May 2011    Post subject: Reply with quote
To be honest i don't know much about mopeds and i'm just going on what people told me...
When im riding the moped its fine and runs like a dream, its just when i brake and nearly come to a stop it cuts out...
So somewhere there is a wiring fault?...
Where about would the fault come from?...
The moped is mint and looks hardly used and it only has 2500 on the clock...
savage1987
PostPosted: 22:39 - 19 May 2011    Post subject: Reply with quote
I also have a short video clip of the moped cutting out if you want to have a look?...
Nope.
PostPosted: 22:43 - 19 May 2011    Post subject: Reply with quote
Oh so it does run and ride then? In which case disregard what I said about cleaning the carb above. Can you take a photo of what screw your using to adjust the idling for us? You may be adjusting the throttle cable rather then the idling hence why its not making much difference!
If the video is online you can link it here so we can have a look.
savage1987
PostPosted: 22:48 - 19 May 2011    Post subject: Reply with quote
Yes it does ride lol...
What i have tried is adjusting the throttle idling pic (the one with the spring) to adjust the revs...
There is also another screw on the side of the carb which im guessing is the air mixture?
My moped is a 4 stroke if thats any help...
The video is on my phone..Is there any way i could send it to you?...
Also i don't have pictures of the carb and can't do it now as it is too dark and will take pictures tomorrow...
savage1987
PostPosted: 14:27 - 20 May 2011    Post subject: Reply with quote
These are the pictures of my Carb and also show you pipes that doesn't connect to anything and hopefully you can identify them for me...
savage1987
PostPosted: 21:57 - 20 May 2011    Post subject: Reply with quote
Just to let you know mate, i rode it for a few seconds and as soon as i started to go up a hill it lost all revs and cut out...Stars again after a few attempts and rides but as soon as you hit a slight hill it cuts out...
The last post was made 15 years, 152 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 65.79 Kb
