fairing repair advice
GPZ500chris
PostPosted: 11:23 - 20 May 2011    Post subject: fairing repair advice Reply with quote
Broke front fairing on my 1998 GPZ500 after accident with back end of a tractor. The fairing is in two pieces so need to connect at the top and bottom and fill the square hole that the tractor made with something. I have the indicator as well so no problems here. The fairing is a type of solid black plastic. (acrylic perhaps?)
Any advice on materials to fill in the hole?
Any advice on ways of fixing the fairing back together?
see pics
https://imageshack.us/photo/my-images/844/img0862di.jpg/
https://imageshack.us/photo/my-images/600/img0864ly.jpg/
thanks!
Nope.
PostPosted: 11:27 - 20 May 2011    Post subject: Reply with quote
1st) Ouch! that sounds painfull...
2nd) Plastic welding is your friend =D check on ebay for some plastic repair kits.
GPZ500chris
PostPosted: 11:34 - 20 May 2011    Post subject: Reply with quote
Not painfull at all!
Just a glancing blow, kept the bike upright and a friendly trucker even lent me a bungee strap so i could take the broken fairing piece home with me!
jimbothe
PostPosted: 11:59 - 20 May 2011    Post subject: Reply with quote
This Thumbs Up
I would also buy some meccano and no, I'm not joking. The metal strips with the holes in are great for bridging cracks in fairings and the holes allow you to either drill and screw (underneath, out of sight) or you can stick them directly on with some good, strong glue and then plastic weld over the top.
The holes allow the plastic weld to bond either side of the strip and through the holes.
With such a break as yours I would also build the inside up a bit with some plastic padding glass fibre and resin as well.
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
PostPosted: 12:25 - 20 May 2011    Post subject: Reply with quote
That's pretty screwed. I doubt you'll ever get a good cosmetic result but you should be able to get a functional one.
One thing that will pose a problem is that you've lost a headlight mount. From experience, these are a total pain in the arse to repair.
With damage that extensive, I'd suggest cutting out a couple of bits of aluminium plate, glueing them to the inside then drilling through the fairing and plate together round the edges and fixing it with pop rivetts.
https://www.bikechatforums.com/download.php?id=78843
I might be tempted to do the same on the outside with a thinner bit of plate then paint it up.
https://www.bikechatforums.com/download.php?id=78842
I did a similar thing on mine using copper sheeting (easier to bend) It would look neater painted.:
https://i48.photobucket.com/albums/f216/stinkwheel/gpz/gpzright.jpg
Teflon-Mike
tl;dr
PostPosted: 14:17 - 20 May 2011    Post subject: Reply with quote
I would probably do it all in plastic, using 'scrap' from old staka-boxes, coat hangers, anything else of similar plastic feel & texture I could find not thrown away, with a cheap 15w Weller soldering iron....
I would get a 'good' cosmetic finish... because I wouldn't simply work from behind, I'd work front and back to get good penetration, and do a LOT of building, which I'd then filled and dress afterwards, before taking entire fairing section back to bare plastic, using filler primer to get a new level, then flatting, priming and sanding before adding paint & laquer.
It would NOT be a quick fix, and it would take an awful lot of patience and time wielding the soldering iron, working on a 50p sized area at a time.....
For a quick 'bodge', I'd simply glass it. Score the plastic around the wound, to get adherance, then lay up glass fibre over the hole and a WIDE area around to strentgthen the repar.
Flipping it over, I'd then fill the missing plastic with some chopped up glass and more resin, and then skim over with filler, or my own home made skimming compound...... epoxy mised with talcum powder to the consistency i want!
Sand and paint to desired finish.
kramdra
PostPosted: 00:47 - 22 May 2011    Post subject: Reply with quote
My repair I substituted glass fibre for a dish cloth. Works quite well, gives a structure to the resin. . . where can one buy glass fibre?
Frost
PostPosted: 00:57 - 22 May 2011    Post subject: Reply with quote
Halfords, the tissue stuff is better than the mat.
The last post was made 15 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.38 - MySQL Queries: 13 - Page Size: 63.72 Kb
