fuel tap/flooding problem
PSNOWDONPAUL3
PostPosted: 20:22 - 20 May 2011    Post subject: fuel tap/flooding problem Reply with quote
hi people.recently joined the forum,so sorry if this thread already exists.ive been doing a restoration/refurb on a 1991 nc30.all body work mods are done and have come to start the bike today before new fairing goes on.theres a new battery,plugs and leads on.ive checked the reg/rec following haynes manual instructions.ive got good sparks and fresh fuel.the tank was swilled out 3 times before final filling.
on starting it just floods.ive checked theres a vacuum from the vacuum pipe and it sucks like a good en.i took the tank off,opened the fuel tap and petrol pissed out.i know that this should only happen if theres a vacuum applied to the pipe.so i stripped the fuel tap down and checked the diaphram for damage.its fine,with no rips or fouling.
to cut a long story short-i put it back on the tank,and when put on the on position it didnt leak fuel-as it shoulnt.back on the bike,after whipping plugs out and drying them.turned it over-nothing but the strong smell of fuel.stripped tap down again,and strectched the spring,built it up and had a friend suck on the vacuum connection,while i sucked on the fule out connection.when he stopped,the fuel out stopped-hey presto!!
last bit-sorry!
tried it again-nothing.so yet again stripped it but built up half of the tap,sucked on the vacuum connection and the diaphram moved,then returned v e r y s l o w l y.think that it is stopping fuel,but is letting too much in as it shuts? any ideas very welcome !!
temeluchus
PostPosted: 20:44 - 20 May 2011    Post subject: Reply with quote
You will have to have the carbs off and get the float bowls off.
Check the condition of the float needles, in particular the tips. If they have a worn step in them they will need to be replaced. The tips should be smooth with no obvious wear or shouldering.
Also check the condition of the floats and their adjustment. Do they float in some petrol, do they move freely?
PSNOWDONPAUL3
PostPosted: 20:54 - 20 May 2011    Post subject: Reply with quote
cheers for that.should of mentioned-ive done no engine work and the bike started alright before i started cosmetically messing,about a month ago.i have got a new tap on the way just incase it is a sticking daiphram.
PSNOWDONPAUL3
PostPosted: 21:29 - 20 May 2011    Post subject: Reply with quote
prime position? oh dear..........
PSNOWDONPAUL3
PostPosted: 22:18 - 21 May 2011    Post subject: Reply with quote
hi guys.just a quick update......am now ready to sell this as a work in progress!! checked floats and carbs today,fitted new tap which works perfectly and checked sparks.had air box off,squirted easy start into carbs,and it "fires" but wont hold its own.so f*****g annoyed with it!!
any ideas please? ive said that if its not running by mid week its going-as its kept at my work its beginning to get in the way
PSNOWDONPAUL3
PostPosted: 22:55 - 21 May 2011    Post subject: Reply with quote
cheers for that vincent.im working tommorow so ill have a look.its got to the point that im nearly out of patience with it!
The last post was made 15 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 5.38 - MySQL Queries: 13 - Page Size: 66.2 Kb
