unstable front end ?
rockers
PostPosted: 22:47 - 20 May 2011    Post subject: unstable front end ? Reply with quote
hello all, had a small butt clentching moment, going round a roundabout no to fast but with a fair bit of lean, and felt like the front end went a little, now if seems when im cornering it feels like ive got a front flat tyre, but its not its at the correct pressure, just feels like it could loose grip like the steering is heavy....
Is this me or what should i look at on the bike ?
cheers
CaNsA
PostPosted: 22:54 - 20 May 2011    Post subject: Reply with quote
What bike, what tyres, road conditions, how warm were the tyres, how fast.
cheers
rockers
PostPosted: 23:11 - 20 May 2011    Post subject: Reply with quote
zx7r, bridgestone tyres cant remember (if needed can find out tomorrow)
road was dry and smooth no stone chippings, warmish tyres i would guess probably riding for 15 min or so
no too fast only about 30 but it was round and back where i came from.
Its just the front end feels different, slow and not gripping- is this me needing to grow a set or could something wrong with the bike ? tyre pressure fine grabbing front wheel and handle bars there is no play.
thanks
Old Git Racing
PostPosted: 01:42 - 21 May 2011    Post subject: Reply with quote
ZX7R's are renowned for their front end feel, could just have been something on the road. If your confident all is right with the bike just put it down to something that can happen every day and don't let it put you off. Roundabouts are the worst place for fluid spills, bet it feels ok everywhere else?
OGR
Frost
PostPosted: 02:24 - 21 May 2011    Post subject: Reply with quote
Check tire wear, profile & width, brakes aren't dragging, check fork preload and damping.
If all of those are fine it might be head bearings.
rockers
PostPosted: 02:30 - 21 May 2011    Post subject: Reply with quote
Thats what i mean, it feels different after that if i go out now round roundabouts and tight corners the front end feels sluggish, so only last thing to get is headstock bearing, is that just front brake on and rock back and forth to check for play or is there a more in depth way of checking.
they tyre is wearing like how it should i guess, cant be no more than 700mile old tyres.
thanks
Rocky
temeluchus
I've had a rear wheel bearing go, and it felt like the front had gone. Foxed me for a while.
CaNsA
PostPosted: 12:15 - 21 May 2011    Post subject: Reply with quote
I have heard that,
If it feels funky at the front, have a look at the back.
PostPosted: 12:36 - 21 May 2011    Post subject: Re: unstable front end ? Reply with quote
A twitch from the front end can often be the rear JUST losing traction - as it slides a little bit, the front end twitches in to compensate.
Check wheel bearings front and back as well as head stock bearings and rear wheel pressure too.
0ddball
PostPosted: 13:15 - 21 May 2011    Post subject: Reply with quote
I had a similar problem with mine. One day the front tucked on a roundabout but i thought it was just one of those things, a bit of gravel or something. Then over the next few days it happened again several times, mostly twitches but one big one where i had to stamp my foot down injuring my hip. I just lost confidence in the bike.
I'm still not sure what the problem was but a new tyre sorted it despite the old one looking fine. It was a supercorsa race scrub so maybe that had something to do with it.
ZXR750L
PostPosted: 14:03 - 21 May 2011    Post subject: Reply with quote
Race tyres are more sensitive to heat cycles than normal tyres - so go through a lot of heat cycles and they can lose grip before losing 'tread'/rubber depth.
Often see this with fronts, where I'm not really abusing the tyre much on the road to wear it down THAT much, but it's getting heated up and cooled down a fair bit.
rockers
PostPosted: 18:08 - 21 May 2011    Post subject: Reply with quote
ok, tyre pressures are both spot on, front and rear
no play in the wheel bearings or the headstock bearings
the steering is nice and free.
the guy i got the bike of said the tyres were about 200miles old, i have done at least 500miles no more that 700, so tyres should befine right ?
havent pushed the bike that hard but the bike should out do me on handling.
intend to go out on a ride tomorrow just dont really want to ride if its dangrous, if its not then need to build up again.
cheers all
The last post was made 15 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 69.53 Kb
