| ace-card |
 ace-card Nova Slayer
 Posted: 23:51 - 23 May 2011 Post subject: Mod 2 prep questions |
I’ve been riding around for the past year, gaining valuable experience and preparing myself for my Mod 2 A2 restricted test which is now booked for 8th June! I have gone this route as I am not in a position to spend hundreds of pounds on instruction, but am pretty confident that I am nearly riding to standard. I have scouted all over the internet, bought books, watched videos and put all this into practice every day to try and ensure a pass, but there are still a few things that I would be grateful for some guidance on:
1) What lifesavers should I be making JUST BEFORE entering a roundabout. I have seen in some places that if going left or straight on, swing a right lifesaver before entering the roundabout and if going right, to swing a left lifesaver (these are the most exposed places). Is this correct?
2) I have heard conflicting information about mini roundabouts and the observations required on them. Should I been treating them as T-junctions or the same as a larger roundabout?
3) Should I try and overtake someone doing 40-50 on a 60 dual carriageway? I was thinking no as my little 10hp CG with 95kg on top could land me in a sticky situation!!
4)Finally, and the one that’s been bugging me the most…..if a single lane splits into two, obviously OSM is required before positioning myself for the correct lane. However, as I’m not technically changing lane, is an indicator signal required?? Again I was thinking no as this could be misleading.
Thanks, it’s such a mind-field out there! I've searched all over but still can't find definite answers!....maybe there are none and it just depends on the examiner you get!! |
| shereen |
 shereen World Chat Champion
 Posted: 09:46 - 24 May 2011 Post subject: Re: Mod 2 prep questions |
| ace-card wrote: | I’ve been riding around for the past year, gaining valuable experience and preparing myself for my Mod 2 A2 restricted test which is now booked for 8th June! I have gone this route as I am not in a position to spend hundreds of pounds on instruction, but am pretty confident that I am nearly riding to standard. I have scouted all over the internet, bought books, watched videos and put all this into practice every day to try and ensure a pass, but there are still a few things that I would be grateful for some guidance on:
1. Just before entering a roundabout, if going left, check mirror, indicate, then left lifesaver and then move to the left of the left hand lane. As you are coming off the roundabout do a right hand life saver.
If you are going straight over check mirrors, lifesaver which ever way you are moving then position yourself in the correct lane, indicate left when coming off and do a right hand lifesaver.
If going right at a roundabout check mirror, indicate right, then right lifesaver, then move to the right hand side of the lane. Indicate left coming off the roundabout and do a right hand lifesaver.
2. Mini roundabouts should be treated like a roundabout. The answer is in the question
3. Yes, you have to overtake on a dual carriage way if someone is going vastly slower than they should be. If the are sitting at 55mph I would just stay behind, but anything less overtake.
4. No indicating on this, just OSM.
This might help too:
https://www.lightningpass.com/jkcm/COURSE+INFORMATION/HOW+TO+FAIL+YOUR+TEST
And this:
https://www.lightningpass.com/jkcm/COURSE+INFORMATION/MOTORCYCLE+TEST+QUESTIONS
Good Luck  ____________________ "The Internet is the first thing that humanity has built that humanity doesn't understand, the largest experiment in anarchy that we have ever had" |
| Lyam |
 Lyam Spanner Monkey
| blurredman |
 blurredman World Chat Champion
 Posted: 14:43 - 24 May 2011 Post subject: |
| Lyam wrote: | It's your life at the end of the day, if you think you can teach yourself better thann an instructor with years and years experiance, than good for you, My instructor told me something inteesting once "Im not teaching you just to pass a test, im teaching you to stop becoming an organ donor" |
Indeed, I did my test on my own and I feel sometimes that maybe I should have had training. And I probably would have if it didn't cost so much. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| ace-card |
| Jodie |
 Jodie Crazy Courier
 Posted: 22:10 - 24 May 2011 Post subject: |
I did it this way Ace last year. I ran almost a year on my cbt which I found good, being a fair weather rider I didn't feel under pressure. I just gained valuable road experience.
I did have a lesson the day before my Mod 1 and Mod 2 though which was good as the instructor gave me a huge confidence boost, showed me all the 5 test routes in the area, where to position myself on a few bad roundabouts in the area and told me what to expect and watch out for.
Think it cost about £100 for the day but I think it's well worth it and would definitely recommend it.
Cost me about £290 all together.
Good luck  |
| ace-card |
| Frog |
 Frog Traffic Copper
 Posted: 19:16 - 25 May 2011 Post subject: |
Couple of thoughts:
1. You can't pass on a lesson. One lesson plus one test costs more than two tests, so it would be cheaper to not take the lesson as long as you pass on the first or second go.
2. Mod2 training consists on learning the routes. IMHO, I'd rather learn to ride than learn to pass. If you're safe on a route you don't know (I.e. Haven't been taught by an instructor), you'll be safe on your own. However, if you pass by being taught how to ride the routes, this doesn't mean you are safe.
Conclusion? Cheapest way *should* be to take the test, but, IMHO you should then take further training.
However, I havent got round to that yet, so maybe you shouldnt listen to hypocritical 'ol me...
Ummm.. HTH..? ____________________ CBT 23/09/10 - Theory 19/03/11 - Mod1 19/04/11 - Mod2 06/05/11
Bikes: CBF125 (sold 30/10/10-25/09/12) - CB400 24/06/11 (broken) - ER6-f 25/09/2012  |
| ace-card |
 Posted: 11:27 - 26 May 2011 Post subject: |
I downloaded 12 test routes used in Bristol, so have been slowly working my way through those and studying Google Earth to see best lane positioning for roundabouts etc......
More training would be v. sensible......It's always been my intention to do some form of advanced riding at "some point" after getting the DSA test crap out the way From what I've read and seen about post-test training, and correct me if I'm wrong, if you rode like that on test, you'd fail?? Seems strange! |
| Frog |
 Frog Traffic Copper
 Posted: 15:02 - 26 May 2011 Post subject: |
Some things definitely. I suspect that the "ride in the middle of the lane at all times" will change, and a few other things too.
I think there's a real value to getting experience yourself, and forcing yourself to do the lifesavers, shoulder checks etc., until they become habitual.
After that I suspect I'll go for more training, but its a long while off yet... I haven't even got my bigger bike yet (although it hopefully won't be too long).
I guess it's each to his/her own... You've got to go on your own riding style and abilities methinks.
Are you confident / have you made your mind up whether to go training or just try and see? ____________________ CBT 23/09/10 - Theory 19/03/11 - Mod1 19/04/11 - Mod2 06/05/11
| Gazza M |
 Gazza M Crazy Courier
| ace-card |
 Posted: 16:37 - 26 May 2011 Post subject: |
Cheers for the heads up Gazza. I'm torn on what to do now....
As Frog pointed out, 2 tests = £150, a day lesson to iron stuff out and test = £175. That being said, the waiting time now for Mod2 is nearly 2 months (been checking everyday for cancellations!). So if I did fail first time, it would still be cheaper, but would take longer (assuming I passed second time). Then again, I could pass first time, in which case, both cheaper and quicker!! Ahhhhh!
Anyone fancy casting an expert eye on some not-so straight forward roundabouts if I post them up?? ____________________ 2007 Skyjet SJ-125, 2001 Aprillia RS125, 1988 Honda CG125, 1997 Yamaha YZF600R
Mama said "life is like a box o' chocolates....have what's nice, then offload the crap to everyone else!"  |
| Frog |
 Frog Traffic Copper
 Posted: 16:46 - 26 May 2011 Post subject: |
| Gazza M |
 Posted: 16:53 - 26 May 2011 Post subject: |
to be honest - I was all for doing it on my lonesome. I rang up the training school as they had slots i could do, the ones on the DSA website were far too long ahead, so I wouldn't been able to make the dates! it really helped me though - pretty sure I wouldn't have passed if I hadn't had the lessons. I'd say get just the one session before it specially for me, I'd been riding since mid November on the CBT wtih no other instrcution so had picked up a few bad habits on the way round!
may as well stick the pics up, i'm sure someone can help  ____________________ Past: '07 YBR125, '00 GPZ500S, '99 ZRX1100, '98 CBR600 track bike, '97 ZX9R
Present: '05 R6 track bike, 140 pit bike |
| ace-card |
 Posted: 17:12 - 26 May 2011 Post subject: |
Ok, here goes....
Just wondering how you guys would tackle these (lane positioning/indication), going from the red arrows to the green.
Cheers guys!  ____________________ 2007 Skyjet SJ-125, 2001 Aprillia RS125, 1988 Honda CG125, 1997 Yamaha YZF600R
| Beelzebob |
 Beelzebob Spanner Monkey
| shereen |
 Posted: 09:04 - 01 Jun 2011 Post subject: Re: Mod 2 prep questions |
| Beelzebob wrote: | | shereen wrote: | If going right at a roundabout check mirror, indicate right, then right lifesaver, then move to the right hand side of the lane. Indicate left coming off the roundabout and do a right hand lifesaver. |
First bit yes, on approach. Last bit no, no, no.
The theory is, lifesavers on a roundabout are to check if something is going to hamper your exit. Doing a right lifesaver on the middle of a roundabout will give you a delightful view of the middle of the roundabout. Should be a left one, to check if anything is steaming up the inside that might hit you on exit - so that if there is something there, you have the chance to continue round rather than going splat.  |
Sorry did mean left, too many right left right lefts in my post!!!  ____________________ "The Internet is the first thing that humanity has built that humanity doesn't understand, the largest experiment in anarchy that we have ever had" |
The last post was made 15 years, 148 days ago. Instead of replying here, would creating a new thread be more useful? |
