| map |
 map Mr Calendar
 Posted: 09:53 - 25 May 2011 Post subject: Kawasaki GT550 - help with throttle needed |
Hi,
Came to try and start the old GT550 last night and had a problem.
The bike had been blown over in the recent high winds (had been left on centre stand). Didn't think anything of it as battery out being recharged and only mirror snapped .
However, put battery in and tried to start. Throttle very loose and didn't turn as it should. Obviously bike couldn't start. I can only think the fall affected this.
Tried to quickly remove switch gear and possible rounded off Philips screw underneath (it was past 9:30pm ish by then).
Had tank off and cable at carb end looks ok but I admit I need to have another good look in daylight (I'm not with the bike ATM).
Now I understand there are two throttle cables, a push and a pull. I have never had to work on this before and the Haynes manual doesn't mention the throttle or associated bar switch gear.
So, as always, any help and pointers appreciated.
Thank you in anticipation  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| yen_powell |
| hazza |
 hazza World Chat Champion
| 69chris |
 69chris Trackday Trickster
 Posted: 10:35 - 25 May 2011 Post subject: |
just dont hit it too hard
the plastic big K used in the switchgear seems to turn to glass over a few years and WILL break if your not careful |
| map |
 map Mr Calendar
| yen_powell |
| m0l0t0v |
 m0l0t0v World Chat Champion
 Posted: 01:02 - 26 May 2011 Post subject: |
So when you twist the throttle you can't see the cables/anything moving?
Would seem either the throttle cables have snapped, or have worked loose... ____________________ '99 Hornet 600 , VFR 400 NC30 '92 , Kasawamasaki GT 550 , '98 Hornet 600
**\Tarmacsurfer/** said: It's that immaculately manly coiffure of yours isn't it. One glimpse of your virile locks and the punters can't wait to buy whatever it is you suggest, as it might let them be just a little bit like the Adonis that is our very own Molly Doovydoo said: Its not my fault I can't get it up properly, I just wasn't blessed  |
The last post was made 15 years, 140 days ago. Instead of replying here, would creating a new thread be more useful? |
