| The Artist |
 The Artist Super Spammer
| cb1rocket |
 cb1rocket World Chat Champion
| yen_powell |
 yen_powell World Chat Champion
| Ichy |
 Ichy World Chat Champion
 Posted: 22:13 - 25 May 2011 Post subject: |
Why the urgency to get it out? Is something else busted?
I'm not home until Monday but I still have the smaller wheel that was on your other bike.
I'm guessing it seized on the bearing or the spacer bush in the center of the wheel so the chance of not having to replace some internal parts is slim.
At worst you need a spare axle. Grind the head off the existing one and you should be able to pivot the wheel out of the swingarm. Swap your shagged wheel for the small one and I'll sort it out at some point over the next couple of weeks.
I think the wheel bearings and maybe seals cost about £10 for a full set. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| Ichy |
 Posted: 22:19 - 25 May 2011 Post subject: |
Just wondering what inside the wheel could stop the axle turning? It only goes through a few bearing and a couple of bushes. Surely they should rotate with the axle?
Is the wheel spinning ok?
Have you done any of your wonder welding and welded the axle to the swingarm by accident? ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| The Artist |
 Posted: 12:57 - 26 May 2011 Post subject: |
I havedn't bodged anything on this one, it is just corrosion.
Doesn't spin at all. Socket on the end and me bouncing made the bike wheelie then fall over and break my clutch lever.
I have a new C&S kit to fit. Not urgent but if you saw my current rear sprocket you may disagree. There are no teeth left and if I rev it slips.
I would rather not destroy the axle but I may have to. Wheel spins fine, barely any friction.
I am thinking maybe single tracker in Crewe can help. If they want to replace everything rather than fix, I will grind off the ends and take you up on that wheel swap offer.
Ugh, chainging c&s on these bikes usually takes about 25 minutes |
| Ichy |
The last post was made 15 years, 142 days ago. Instead of replying here, would creating a new thread be more useful? |
