| stinkwheel |
 Posted: 18:48 - 27 May 2011 Post subject: Could someone look something up in a CB500 manual? |
I'm looking for the allowable warpage on a front brake disc in my quest to track down the reason for it pulsing at the brake lever. It's a CB500SY.
I've got about 0.15mm at the outside edge and 0.07mm at the inside edge of the braking surface.
Also, oddly, the disc itself appears to be slightly oval. If I put the dial guage against the edge of the central rim of the disc, I get 0.4mm runoff. Can't think that this would affect the braking performance though and it could just be that they didn't machine this part to the same sort of tolerance since it isn't directly involved in the braking process.
I'm uploading a couple of videos showing this. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 18:54 - 27 May 2011 Post subject: |
Nothing mentioned in the workshop manual, but Haynes says :
Disc Thickness (all models)
Standard : 4.80 to 5.20mm
Service limit (min) : 4.00mm
Disc Maximum Runout : 0.10mm ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| stinkwheel |
 Posted: 19:05 - 27 May 2011 Post subject: |
Maybe at the high side then.
Mind you, it's usually on the middle of the disc working surface that you measure it in which case it's pretty much bang-on the limit taking an average of the inner and outer edge readings (there's nowhere in the middle without holes to put the dial guage on).
Video
Still, I think the pulsing is really excessive for that amount of runout. It did it with the old disc and it's done it with this disc since it was new out of the box. I think I'll see what difference the new wheel makes. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| stinkwheel |
| Robby |
 Robby Dirty Old Man
| stinkwheel |
The last post was made 14 years, 321 days ago. Instead of replying here, would creating a new thread be more useful? |
