riding after test on a retricted bike
retrobiker
PostPosted: 17:52 - 27 May 2011    Post subject: riding after test on a retricted bike Reply with quote
so i am due to take module 2
i am currently riding a cg125... great bike
but i have this other bike a honda cb550 f2 77 vintage
i know i would have to take it easy but would like to take it out every now and again when i have passed the test
if i am right when new many moons ago it had roughly 46 hp,
so question is..... is it possible/ how to restrict the bike to 33hp
take it no "kit" exists for a bike this age so what to do
PostPosted: 19:04 - 27 May 2011    Post subject: Reply with quote
Other 4 cylinder engines want approximately 15mm holes in each of 4 restrictor washers to get them down to 25kW/33bhp. Might as well start there and get on a dyno.
PostPosted: 19:15 - 27 May 2011    Post subject: Reply with quote
I suspect the CB550 uses slide carbs and they will probably not like the restrictor washers (which work by restricting air flow, and with CV carbs it is this airflow that moves the slide to adjust the mixture, rather than the slide just being connected directly to the throttle cable).
Some kind of throttle stop is probably required.
Note that the legal limit is 25kW "net power output". This is probably meant to be a crankshaft figure rather than a rear wheel figure.
retrobiker
PostPosted: 21:08 - 27 May 2011    Post subject: Reply with quote
cheers guys
throttle restrictor keeps coming up. plus a member on another forum has mentioned this as well
make a slightly longer inner cable so you cant fully open the throttle hence not open the carbs fully
wonder what insurance will make of this
thanks again
el_oso
PostPosted: 21:22 - 27 May 2011    Post subject: Reply with quote
as far as i know there is no 'correct' legal way to restrict the bike. throttle stop is probably the easiest way.
a friend at the bike club has a throttle stop for his r6 which has been declared to his insurance company
Duke 390
Car: Jeep Wrangler 4.0L
ThoughtContro...
Choose your insurance company well. Some may be awkward and ask for a dyno printout or even worse insist on the mythical restriction certificate.
Others wont ask at all, until claims time at least.
H&R are paperwork lovers, Carole Nash certainly aren't in my limited experience.
Prize cunt
PostPosted: 23:07 - 27 May 2011    Post subject: Reply with quote
Would give you a horrible slack throttle.
With single slide carbs one trick is to put a length of pipe over the cable inner between the cap on the carb and the carb slide.
0l0dom0l0
PostPosted: 20:35 - 28 May 2011    Post subject: Reply with quote
I've used a cable crimp on mine to restrict it. Works well so you could do that. Thumbs Up
The last post was made 14 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2 - MySQL Queries: 13 - Page Size: 62.09 Kb
