Kick starting a small single
Peterthepillo...
PostPosted: 10:01 - 28 May 2011    Post subject: Kick starting a small single Reply with quote
I have a monkey bike retrofitted with a chinese (lifan) 100cc pitbike engine. There is no electric start, the motor is a Honda pattern thing and could not be more basic or traditional.
I always seem to make a hash of kick starting it, it seems very tight over compression and either doesn't fire with too little choke, or kicks back with too much.
I am sure that one day the kick starter will just break the forces seem excessive. I had hoped that it would lose some tghtness over time but this hasn't happenned yet.
Once it's running it is just fine.
I wonder if there is a procedure for getting these things running that newbies like me have never had to learn.
A passage broad, smooth, easy, inoffensive down to hell.
robocog
PostPosted: 10:18 - 28 May 2011    Post subject: Reply with quote
Worth checking the valve clearances are set right and timing is where it should be (valves and spark)
My DR was a pig to kick when the cam had eaten into the head and cover (causing randomly variable valve timing and lift/duration)
Soon as this was fixed it kicks over nice and easy and starts as it should without kickback or so much compression it felt like I was going to snap something
Regards
Rob
Needs a bigger garage...
The last post was made 15 years, 28 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.73 - MySQL Queries: 13 - Page Size: 31.8 Kb
