| .Bishbash. |
 .Bishbash. World Chat Champion
 Posted: 11:28 - 28 May 2011 Post subject: Firing on 3 Cylinders |
OK this bike is doing my nut in. It's a VFR400 NC24 (cue Robbie for a disliking reply on NC24s).
OK Dom and myself have tried everything we know to get this going.
What we've done so far;
Ensured all plugs/colis are working
Fuel is getting to the carbs
We cleaned the carbs out, all jets are clear
Cylinder one is the problematic cylinder. It does fire, but only if you cover the air inlet trumpet to the No.1 inlet. Then after a few seconds goes back to firing on 3.
Now it has worked in the past and has only stopped working by being sat for about 5 months. Would have thought the carbs to be the problem, but nothing is blocked.
Any help would be hugely appreciated.
Thanks
Neil ____________________ Current bike - GSX-R1000 k8 |
| Pete. |
 Pete. Super Spammer
 Posted: 11:45 - 28 May 2011 Post subject: |
If you have a spark then it's either fuel or compression related. If it worked before being stood-up but now doesn't that rules out compression so get the carbs apart again. ____________________ a.k.a 'Geri'
| .Bishbash. |
 Posted: 12:47 - 28 May 2011 Post subject: |
You reckon? What to look out for? it was spotless in there and everything seemed fine.
Would getting them balanced help at all? ____________________ Current bike - GSX-R1000 k8 |
| Casper |
 Casper World Chat Champion
 Posted: 13:43 - 28 May 2011 Post subject: |
there is a channel that the fuel goes up when on choke. stick a strand of wire up to make sure this is clear. Take out the main jet and washer, take the top apart and out with the slider and needle. the brass part that the main jet came out of, stick a bit of soft wood like a pencil over it and tap it out. make sure all the holes in this cylinder are clear. Get a tin of compressed air from a computer shop (This Asda sells it) and blast this up all vents. I have a PDF that explains what direction the fuel takes at different levels. Its different carbs to yours but gives you an idea. If you want it mail me at rolfe66@gmail.com , Its to big to add as an attachment to this post. I had the same problem and cleaned the carbs many a time, at the end of the day i kepped missing a part when cleaning.
Oh, there is also a mesh under the float needle, take needle out and check the mesh is not blocked, it should pull out with a pair of nose pliers.
Good luck |
| Pete. |
 Pete. Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 14:48 - 28 May 2011 Post subject: |
I cut the relevant pages from the PDF and attached them here. Should make it very easy to understand the operation of carbs at various stages of throttle opening: ____________________ a.k.a 'Geri'
| Casper |
| Pete. |
 Pete. Super Spammer
 Posted: 15:08 - 28 May 2011 Post subject: |
I use PDFill. It installs as a printer, so you just open anything that you could normally print but select the PDFill virtual printer and instead of spitting out paper it generates a PDF.
To print part of a pdf, just go to print it as normal then specify the pages you want. Change the PDFill printer properties to black & white and turn down the DPI to reduce file size. ____________________ a.k.a 'Geri'
| Casper |
 Posted: 18:10 - 28 May 2011 Post subject: |
Cheers Pete. Works perfect  |
The last post was made 14 years, 302 days ago. Instead of replying here, would creating a new thread be more useful? |
