Would this work? Opinions from all walks please :)
sandman1976
PostPosted: 09:55 - 29 May 2011    Post subject: Would this work? Opinions from all walks please :) Reply with quote
Right here goes,
Most of you will know the honda pumper type carbs.
Could i run a spur from the fuel line, down a pipe, into a small squish type pump which is pressed by the throttle when its wide open which pushes extra fuel to a jet on the back of the carb into the air intake?
More to the point, would it give me a better wide open throttle response?
Even more to the point the delorean will only fire into the future if it reaches 88mph!... Ohh sorry wrong movie Smile
Yea anyway... Any opinions?
Tarrrr Smile
serlant
PostPosted: 10:18 - 29 May 2011    Post subject: Reply with quote
Just sounds like an accelerator pump? (or is that what you mean by "pumper type carb"?)
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
sandman1976
PostPosted: 10:29 - 29 May 2011    Post subject: Reply with quote
Yea i think thats the basic principle...
So does it work?
I just have this nagging in my head telling me it will over fuel and bog it or something...
MickC
PostPosted: 11:02 - 29 May 2011    Post subject: Reply with quote
Ok on my bike i have a set of CB900 Custom carbs that are fitted with the accelerator pump. It draws fuel out of float chamber 2 at a set rate so giving it its own fuel supply probably wouldn't make any difference, it can only pump so much. As far as i know the pump system was originally meant for the US market, where they had tighter emmision controls than we had here. If your bike doesn't have one yet you should notice better acceleration (have run mine on the type with and without), but also an increase in fuel consumption.
Had an xv750 that used a vacume valve that did a similar thing, but it would draw fuel from the tank and dump it into the carb/engine mounting(on cylinder 1#), think the v-max had a similar set up, so if you want increased performance that set up may be worth a try - if it could be made to fit. Hope thats of some help.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
The last post was made 14 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 39.59 Kb
