| yuri2085 |
 yuri2085 World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 15:33 - 29 May 2011 Post subject: |
Well 20mm longer is about 1/3 the total travel of the original shock so I guess that's why it makes so much difference. You're trying to jack the back-end up by 1/3 the total movement at the end of the arm.
The shock pushes down on the bottom lever, which is attached to the swingarm via the dogbones. This acts as a multiplier of movement between the shock travel and swingarm. The dogbones travel less than the shock but fix near the front of the swingarm so travel at the arm is greatly multiplied.
You can't just go stuffing a 20mm longer shock in there and hope it will work. You could try removing the lower lever, and flipping it over. It might get you in the right ball-park for shock length since the lever isn't straight but it might also have undesirable effects on the spring-rate. ____________________ a.k.a 'Geri'
| yuri2085 |
| Pete. |
 Pete. Super Spammer
| yuri2085 |
 Posted: 16:43 - 29 May 2011 Post subject: |
Well, that might be worth a go then.
Thanks for the chart, will be useful if I sell this shock and try and get a new one. Clear information about which shock has been very hard to find, I was sure I had it right with this one . |
| Pete. |
 Pete. Super Spammer
 Posted: 17:00 - 29 May 2011 Post subject: |
If you want to experiment with the shock you have by flipping the lower arms, to get the ride-height you're looking for you have to do this:
Figure out your preferred ride-height, by putting planks of wood under the rear wheel and sitting on the seat until you get the feel you want.
Get off the bike and measure the height off the floor at a point on the tail just for reference, support the bike with the weight off the wheel at your ride-height.
Now fit your new shock with flipped-over lower arm and then measure the distance between the dogbone holes with the wheel resting on the floor. This is how long you need to make your new dogbones. ____________________ a.k.a 'Geri'
The last post was made 14 years, 319 days ago. Instead of replying here, would creating a new thread be more useful? |
