Would boiling your brakes do any permanant damage?
PostPosted: 20:15 - 29 May 2011    Post subject: Would boiling your brakes do any permanant damage? Reply with quote
I mean full-on boiling, no pressure at the lever and fluid coming out of the master cylinder, not just fading slightly.
Got a little overenthusiastic checking that the brakes on the CB500 are indeed now working properly without pulsing (they are, and it'll lock the front wheel at 100mph).
I'm sure some of the trackday lot must have boiled their brakes to oblivion before.
They came back once it cooled down a bit but I'm a little concerned I may have cooked the seals.
Nexus Icon
PostPosted: 20:56 - 29 May 2011    Post subject: Reply with quote
I've never done it on a bike but I have in cars a few times. It's never done any permanent damage that I can remember but I used to renew the brake fluid as soon as I practicably could. I've no idea if that's necessary, it just seemed like a good idea.
Greetings from Shitsville!
tatters
Exxon Valdez
PostPosted: 21:04 - 29 May 2011    Post subject: Reply with quote
Have done so on a VFR750 a few years ago thrashing it about the twistys, did,nt have any problems once the system had cooled down but was a bit scary having no front brakes when trying to slow down from 90mph.
PostPosted: 21:05 - 29 May 2011    Post subject: Reply with quote
I wouldn't expect real damage, but I would be inclined to replace the fluid and check the disk and pad condition.
weasley
PostPosted: 22:58 - 29 May 2011    Post subject: Reply with quote
The main damage comes when you have boiled the brakes and are still going too fast to avoid the car/hedge/ditch.
Other than that I would say probably a temporary effect.
PostPosted: 01:39 - 30 May 2011    Post subject: Reply with quote
Cheers guys. Put my mind at rest.
I'll take it out for a run tomorrow just to make sure everything is as it should be (and to take the nibs off the tyres..).
c_dug
PostPosted: 03:21 - 30 May 2011    Post subject: Reply with quote
I thought that was an indication of water in the fluid?
If not surely chris-red would have boiled his fluid in his thread about burning his front disks last week?
PostPosted: 10:01 - 30 May 2011    Post subject: Reply with quote
Stinkwheel I'm a little surprised in all honesty. I thought you were the 'Go-to-guy' in the Workshop area!Wink
It won't have done any permanent damage, no. I would change the fluid though, because although it might not do any permanent damage to the braking system hardware, it might do something to the fluid that I'm not aware of. Its not supposed to boil after all. The fact that it boiled at all is probably indicative of something wrong with the fluid anyway.
Still, sounds like you sorted the brake pulsing. What was the problem in the end, out of interest?
PostPosted: 12:06 - 30 May 2011    Post subject: Reply with quote
Water in the fluid will cause this to happen at far lower temperatures, but get the brakes hot enough and brake fluid will boil as well.
PostPosted: 12:13 - 30 May 2011    Post subject: Re: Would boiling your brakes do any permanant damage? Reply with quote
I'd be looking to replace the fluid with some better fluid (less contaminated) maybe.
While I was at it, I'd be looking to replace the tyre with a good one too Wink.
Never boiled the fluid including with racing and trackdays on road bikes; but believe it happens pretty often at car trackdays and never causes further problems.
PostPosted: 13:00 - 30 May 2011    Post subject: Reply with quote
It was brand new DOT4 fluid from a sealed container put in on Saturday when I fitted the freshly rebuilt calliper, newly skimmed disc, braided steel hose and Armstrong HH pads.
Err. I think I did go rather over the top with the application of said brakes to be honest. Embarassed
Three consecutive "bump and run" emergency stops from three figure speeds on my local "testing circuit". It was fine until I stopped at a junction waiting to turn right and brake fluid started pishing out of the master cylinder. Burned all the greasy fingermarks off the caliper anyway. Maybe I shgould get one of those sweat band things to go round the master cylinder. Mr. Green
I will admit, for a single 2-pot sliding calliper, the brakes are now rather good.
Oh, and it has a fairly new BT45 tyre on although it was possibly not fully warmed up at the first go.
Piercee100
PostPosted: 13:09 - 30 May 2011    Post subject: Reply with quote
My old Capri used to boil its brake fluid every now and again, and noticed that its started to congeal into a jelly. I dont know how old this fluid was but changed it soon after.
Rides: Honda H100a (Retired), VT500e (Sold), Kawasaki ZX400 (sold), Kawasaki GT550 (Sold), Suzuki Inazuma (Daily), Honda CD185t (Broken), LML Star 2t (Last run edition).
0l0dom0l0
PostPosted: 13:16 - 30 May 2011    Post subject: Reply with quote
I'd be careful, I cooked the rear brake on my Fazer at Donington recently. Full on boiling, no pressure on the lever what so ever.
I only overhauled it a few months ago, fully re-built with seals and pads etc.
One of the dust seals is now totally shot, and that piston won't move at all. It has clearly deformed from the heat so stuck itself on the piston.
HTH
PostPosted: 13:53 - 30 May 2011    Post subject: Reply with quote
Should be fine I'd have thought. I wonder if your pads are generating excessive heat which is being transferred through to the fluid or something.
Not sure what the cb500 cup racers use, but pretty sure it's stock calipers and there's plenty of tracks they're going to be getting a lot of abuse.
I've often suffered some fading towards the end of a session, but never boiling.
Ah BT45s - I always found them a bit variable, especially when cold.
PostPosted: 14:33 - 30 May 2011    Post subject: Reply with quote
Nope boiled fluid is usually from constant use not from smashing it on for 10 seconds.
I have boiled the rear in the past in London in the Summer, never had any repercussions.
The last post was made 15 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 89.28 Kb
