Bent Forks?
upanddown22
PostPosted: 21:00 - 29 May 2011    Post subject: Bent Forks? Reply with quote
Got a GPZ500 the other day and manage to get it all restricted and it's running pretty well but will get it set up properly soon.
Anyways...it seems that the handlebars are out of alignment Confused When I turn the bars to the right the end of the bars hit the tank, but when I turn them to the left there is about an inch of clearance between the tank.
When riding it seems the bars are pointing slightly to the right in order to go straight. The bars seem to clamp directly to the fork legs so I can't work out how to straighten them.
Are my forks bent or is there a way to align it all?
Thanks!
Kawasaki GPZ500S 1995
PostPosted: 21:29 - 29 May 2011    Post subject: Reply with quote
Possible the bars are bent and also possible the forks are twisted in the yokes.
To try and straighten the forks in the yokes slacken off the pinch bolts on the top yoke and any around the wheel spindle (so the forks are just held in place securely with the bolts in the bottom yoke). The bounce the front suspension up and down hard a fair few times. The forks will try and go parallel again. Then tighten all the bolts back up again.
upanddown22
PostPosted: 21:35 - 29 May 2011    Post subject: Reply with quote
Thanks Keith, looks like there is a slight bend in the bars but not sure if this standard.
Will try the straightening in the yoke, will report back!
robocog
PostPosted: 21:36 - 29 May 2011    Post subject: Reply with quote
Edited to remove redundant guff and add , it /could/ be the round clip on part (which does unbolt) is bent
https://images.cmsnl.com/img/partslists/handlebar-1994-d1-ex500-north-america_bigkae0193f2310_3374.gif
part 64003
Regards
Rob
Needs a bigger garage...
upanddown22
PostPosted: 21:48 - 29 May 2011    Post subject: Reply with quote
46003? ay does look like mine is bent slightly, but not sure if it's bad enough to explain the difference.
Tricky! Might try and get a cheap one off ebay and see what happens.
Thanks
robocog
PostPosted: 22:02 - 29 May 2011    Post subject: Reply with quote
LOL yup, my bad for rushing Smile
localised heat and a scaf bar over it (clamped in a vice) to get it straight (er) ?
I suppose if its the right hand one that's gone bent, maybe just replacing it is safer (thinking throttle tube snagging type issues)
Regards
Rob
weasley
PostPosted: 23:04 - 29 May 2011    Post subject: Reply with quote
An additional factor regarding the difference in tank clearance could be that a lock stop one side is bent or damaged.
Fairies attack This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 01:01 - 30 May 2011    Post subject: Reply with quote
My bandit bars were bent about 1.5" up and 2" back one side. It put them in my vice and straightened them using a straight edge, a level a square and some angle iron.
upanddown22
PostPosted: 09:36 - 30 May 2011    Post subject: Reply with quote
Thanks everyone, went down to the bike this morning and put a straight edge up against the handlebar, it's bent pretty badly. I think part of the trouble was I wasn't sure if they should be bent or perfectly straight!
Think i'll keep an eye on ebay and get some new ones, very relieved to know the forks are ok!
Thanks
The last post was made 15 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 68.29 Kb
