| Piercee100 |
 Piercee100 Trackday Trickster
 Posted: 17:52 - 29 May 2011 Post subject: Carb problem? |
Got the ignition on my resto Honda Vision sorted (joined the black and red wires) and have had it running kinda- will run like the carbs blocked, boggs down and wont idle. Cleaned carb, fitted inline fuel filter and tried a freshly serviced spare carb but but no luck. Now it will only run if I pour a bit of petrol in the intake and once thats gone it cuts out again.
Could it be a vacume leak somewhere seems like its not sucking in the petrol to keep running although the float bowl is full? I noticed an O-ring split on the cold start device, could this cause this problem since its the only thing left I think, but the unit's connection seems pretty tight in the hole anyway?
Also would the poor running be likely fuel starvation or weak spark? It didnt have the power to pull me up a slight hill or could this be caused by an ignition coil (the spark didnt seem that great) but it does fire the second fuel is pumped into the intake?
Any advice appreciated, thanks. ____________________ Rides: Honda H100a (Retired), VT500e (Sold), Kawasaki ZX400 (sold), Kawasaki GT550 (Sold), Suzuki Inazuma (Daily), Honda CD185t (Broken), LML Star 2t (Last run edition). |
| N cee thirty |
 N cee thirty Banned
| Piercee100 |
| Piercee100 |
 Posted: 11:54 - 30 May 2011 Post subject: |
I've got it running and running well It took what must have been about 75 kicks, stopping every now and again for air and let the carb settle. I put the airbox back on and refitted the fan and cover and its running great but still wont idle (think the engine may have been on its way to seizure so the more its run the better it runs and it will nearly idle but it feels like its holding back- gearbox drag or something.
Anyways, if I let it cut out then it will iether start first kick or will take another 70 odd kicks to get it going again- any ideas? got a new coil on the way so maybe a healthier spark will help. Still not sure if that autochoke works or not, since I've only got the two minimum wires for the ignition connected and not sure what makes this work- do you think it would start better if I got the starter motor working? ____________________ Rides: Honda H100a (Retired), VT500e (Sold), Kawasaki ZX400 (sold), Kawasaki GT550 (Sold), Suzuki Inazuma (Daily), Honda CD185t (Broken), LML Star 2t (Last run edition). |
| N cee thirty |
 N cee thirty Banned
| Piercee100 |
| ahaughey536 |
 ahaughey536 Borekit Bruiser
The last post was made 15 years, 149 days ago. Instead of replying here, would creating a new thread be more useful? |
