Horn Problem
asdf
PostPosted: 18:26 - 30 May 2011    Post subject: Horn Problem Reply with quote
I have a horn problem on my EXC 125. Basically the horn button itself doesn't work. I have managed to get it working by making my own switch. Will it still pass an MOT (got one tomorrow) as an on/off switch rather then a button?
KTM EXC 125 Supermoto, Honda Cub90
Past - Aprilia SR 50 Ditech, Derbi Senda SM DRD, Aprilia RS125 x 2, Aprilia RX 125
69chris
PostPosted: 19:11 - 30 May 2011    Post subject: Reply with quote
im pretty sure (although someone will prob tell me im wrong now iv said that Laughing ) that a switch is ok but it must be a switch that only works will being 'operated', ie not an on/off switch but rather a switch that flicks back to 'off' when released.........if that makes sense Laughing
MickC
PostPosted: 19:35 - 30 May 2011    Post subject: Reply with quote
If you have time before your MOT dismantle the horn switch and try to clean its contacts, might get it working again
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
yen_powell
PostPosted: 19:52 - 30 May 2011    Post subject: Reply with quote
I had a car that I had to get through an MOT. Due to some problem with the immobilisor the hooter didn't work and wasn't going to work without removing the immobilisor which would entail all sorts of misery.
I got an old bike horn, screwed it to the coolant bottle, ran one wire to the battery, then a wire from the other battery terminal into the cab to a home made plastic card switch mount with the words 'Bodge-omatic' written on it, then a wire back to the horn.
I think I slapped a fuse in there somewhere as well.
It passed the MOT no problem although a sticky front caliper was mentioned on the sheet attached.
XT1200Z and a DR350 in bits
asdf
PostPosted: 21:04 - 30 May 2011    Post subject: Reply with quote
Thanks for the replies. The bike has no battery so I had no option of running another horn. Also the switchgear is all sealed and riveted together and I dont have time to put it back together. I've found another switch which I think should be ok. Its a button style which can click on if you push hard but if you push it down normally it self releases.
Pedd
PostPosted: 22:06 - 30 May 2011    Post subject: Reply with quote
A bike will pass with any horn lol, just stop at a bike shop tomorrow and grab a cheap bike bell/horn to get you through
https://www.ladypoolcycles.co.uk/images/Bicycle-basic-bell-ping.jpghttps://ecx.images-amazon.com/images/I/31YTNS500KL._SL500_AA300_.jpg
Dont Click HERE
Current modes of transport = 125 superdream (in bits atm), 1978 GS750 chop, bandit 600(main one), 1982 bmw r100rs,
cx500 trike (hey its fun) oh and the car to ferry the missus and dogs around Smile
Nexus Icon
PostPosted: 22:29 - 30 May 2011    Post subject: Reply with quote
If you can dissemble the new switch you should be able to stop it latching at all by removing or modifying (breaking off) a critical part. Thus it would only operate when you close the switch with pressure from your thumb.
Greetings from Shitsville!
69chris
PostPosted: 22:38 - 30 May 2011    Post subject: Reply with quote
i thought they had stopped that and it had to be electrical now ?? Confused
cb1rocket
PostPosted: 22:40 - 30 May 2011    Post subject: Reply with quote
it has no battery, so how are you running the horn anyway?
yen_powell
PostPosted: 07:12 - 31 May 2011    Post subject: Reply with quote
I don't think you can get away with those anymore, the note has to be continuous.
Quote Me Happy
PostPosted: 07:19 - 31 May 2011    Post subject: Reply with quote
Yeah the note has to be continuous so I use a battery operated push bike horn on my Gas Gas.
Pedd
PostPosted: 09:22 - 31 May 2011    Post subject: Reply with quote
well nobody's told the mot station we all use round here then lol, Loads of the lads still have a little bell/horn on for that very reason.
A ball horn is continuous for as long as its being pressed in Wink lol
Dont Click HERE
truslack
PostPosted: 11:24 - 31 May 2011    Post subject: Reply with quote
"A motor bicycle first used before 1 August 1973 may be fitted with a bulb horn."
"An audible warning device is usually an electrical horn. A horn is defined as an instrument, not being a bell, gong or siren, capable of giving audible and sufficient warning of the approach or position of a vehicle"
No bulb horns after '73, and definitely no bells at all!
The last post was made 15 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 78.25 Kb
