cg125 chain/rear wheel problem
rich262
PostPosted: 08:43 - 26 May 2011    Post subject: cg125 chain/rear wheel problem Reply with quote
hi realy need some help with my cg125 that brought last week after i got it home and took the chain guard off found that the chain looked like it has never been looked at so cleaned it all up and noticed it had tight and loose spots like 20mm difference in the free play. so thought chain must be shafted ordered new chain and sprokets fitted them but is still the same gutted.
im pretty sure its a problem on the rear wheel because i put a mark on the wheel and its allways tightest when its at the top i cant think what could cause this because if it was bearings surely be more random . any idea's thanks
AndyB1989
PostPosted: 08:54 - 26 May 2011    Post subject: Reply with quote
have you checked thewheel is centred properly and running true ?
rich262
PostPosted: 10:31 - 26 May 2011    Post subject: Reply with quote
yer wheel is straight and centered and when spining looks fine its as if the sprocket is off center but it fits fine on to the wheel and cant realy be in any other posishion iv had it off an put it back on but its the same cant get my head around what could cause it
AndyB1989
PostPosted: 11:23 - 26 May 2011    Post subject: Reply with quote
it does indeed sound like the sprocket is off centre ... how odd
lozzypop1
Certified MILF!
PostPosted: 06:06 - 27 May 2011    Post subject: Reply with quote
Not odd if the sprocket carrier has ovalled off... How old is the CG? I had the same type of problem with the ER5, new sprocket carrier fitted and it's right as rain.
rich262
PostPosted: 10:37 - 27 May 2011    Post subject: Reply with quote
hi its a 2001 with 17000 miles on it.
is it a seperate part then i thought it was all part of the hub were it mounts on ill get the wheel back off tomorow and have a look for that thanks
hornetmike
PostPosted: 02:09 - 29 May 2011    Post subject: Reply with quote
All my bike haves had tight and lose spots, might just be wear the chain has worn un evenly and the chain is at the end of it life ?
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
rich262
PostPosted: 19:40 - 30 May 2011    Post subject: Reply with quote
had the wheel back off and the is very slight wear on the hub so this must be the cause wat a bugger cus i think that means a new wheel as it all seams to be 1 part on mine thanks for the replys any way
The last post was made 15 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 53.79 Kb
