| georgewells |
 georgewells Derestricted Danger
 Posted: 21:11 - 30 May 2011 Post subject: CG125 Bike power losing |
Hello and thank you for your previous help with this CG bike.
The bike is now starting within a few kickstarts, to be very honest we have no idea why it now works properly it just started a few days ago and has been ok since.
We have a new problem that you may be able to assist us with.
It has developed a problem at the top end of the power range, when the throttle is opened up fully it acts like it has hit a limiter of some description.
The only way i can describe this is a fast pulse of firing and popping, it is like the bike wants to go but it cannot.
We really need to fix this very soon as my grandson says its frightening trying to get out into traffic from junctions and such.
Any advice is appreciated.
Kind Regards. ____________________ https://www.chattinbubbles.co.uk/
A forum created by my grandsons friend. |
| robocog |
 robocog Traffic Copper
| georgewells |
 Posted: 22:26 - 30 May 2011 Post subject: |
Did you remove/strip the carb and clean it? - This was done professionally.
Is it seated properly on the rubber inlet manifold and nipped up - Yes it is properly fitted.
ditto for the other end seated properly on the airbox - This may be of interest, it has never had an air box it is just a small cone shaped air filter.
Checked all electrical connectors are clean and making good contact? - Yes we have fine tooth combed the electrical system.
Twiddle the fuel mixture screw? - After much searching online to find this, yes we have tried it to the correct recommendations.
check the way the choke opens/closes and make a mental note - The choke is operating correctly, this bike now does not require choke to start/run.
Have you looked at the plugs colour? / changed it for a new correct grade one? - The plug was replaced as soon as we got it some weeks ago.
Have you looked at the air filter? /cleaned oil or replaced it? - As per above question.
Put fresh fuel in there? - Yes tank was emptied and cleaned out.
Checked/done valve clearances? - No, would not know how to do this.
Could this be air filter or air related?
Maybe not getting enough or getting too much?
On a further note my grandson took out the cylinder from the carborettor that moves up and down when you turn the throttle, he tried to dismantle it to clean the long needle and inside the cylinder, when he had done we realised there was more than one position the small C clip at the top of the needle could go on and we had not taken note of it so we put it on the middle one. If this makes any difference please let me know.
Thank You. ____________________ https://www.chattinbubbles.co.uk/
| Nexus Icon |
 Nexus Icon World Chat Champion
| cb1rocket |
 cb1rocket World Chat Champion
| georgewells |
| cb1rocket |
| Nexus Icon |
| georgewells |
 Posted: 22:38 - 30 May 2011 Post subject: |
Could we take off the cone air filter and try it without a filter and see if it does the same? Would this point to the filter if it does?
| robocog |
| Nexus Icon |
| cb1rocket |
| N cee thirty |
 N cee thirty Banned
| 69chris |
 69chris Trackday Trickster
 Posted: 22:47 - 30 May 2011 Post subject: |
as an experiment, before you spend money on airboxs etc...
try wrapping gaffa tape around the airfilter, aim to cover about half of it (thus restricting the airflow) and try the bike, if it improves then your running lean (expected with a cone filter, stock jetting and the needle on the middle clip)
give it a go an let us know  |
| georgewells |
 Posted: 22:50 - 30 May 2011 Post subject: |
It would appear we have an air filter box with a rubber joiner in the box of spare parts the man gave us with the CG.
I will have him fit this in the morning and return to tell you the result.
I will also get a new spark plug in the morning, what are the tell tale signs of a lean mixture on the spark plug?
| Nexus Icon |
| georgewells |
| N cee thirty |
 N cee thirty Banned
| Nexus Icon |
| 69chris |
| georgewells |
 Posted: 11:02 - 31 May 2011 Post subject: |
The plug appear as normal colour but i will change this anyway.
The air box and connector pipe is now fitted, the filter looks like new.
This has not made any difference to the problem we have with the top end of the power.
Are the valves as easy to set as they look on the guides?
| Nexus Icon |
| georgewells |
 Posted: 22:17 - 31 May 2011 Post subject: |
Ok the valves are set correctly, we still have the problem, would you adjust the C clip on the needle now to eliminate that as the offender?
| N cee thirty |
 N cee thirty Banned
The last post was made 15 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
