oil leak problem
bennell09
PostPosted: 19:23 - 30 May 2011    Post subject: oil leak problem Reply with quote
ive annoyingly noticed that on my 2cycle oil tank there is a screw in it plugging a hole that looks like has been made by the previous owner screwing in the air box screw too hard and because the oil tank is directly behind the air box its pirced a hole so hes just bodged it by sticking the screw in to stop the leak. does any one know how i could plug the hole more professionally and longer lasting. im thinking because it holds oil itll be difficult to plug as the surface will be anti stick or something, any input will be a help
cheers
MickC
PostPosted: 19:33 - 30 May 2011    Post subject: Reply with quote
JB Weld might do the trick, you can repair most things with it.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
temeluchus
PostPosted: 20:57 - 30 May 2011    Post subject: Reply with quote
Jbweld or plastic metal are good. Black or clear silicone would also work.
Fairies attack This post is not being displayed because the poster is banned. Unhide this post / all posts.
The Artist
PostPosted: 01:17 - 31 May 2011    Post subject: Reply with quote
Empty oil from tank.
Remove screw
Put a bit of silicon on the screw
replace the screw
Win
The last post was made 15 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 42.75 Kb
