| Yetiboy |
 Yetiboy Derestricted Danger
| Yetiboy |
| Paxovasa |
 Paxovasa World Chat Champion
 Posted: 14:18 - 31 May 2011 Post subject: |
Check the push rod mechanism at the sprocket cover  ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| Yetiboy |
 Posted: 16:21 - 31 May 2011 Post subject: |
Think there are 2 adjusters (not certain, Charlottes 600 Bandit has a ZZR600 clutch lever) and possibly 3. The one on the sprocket cover adjusts the free play in the actual clutch while the one on the bars adjust the free play in the cable, same for an adjust on the cable outer where it meets the sprocket cover.
Slacken off the one on the bars. Undo the lock nut on the sprocker cover adjuster (ie the one under the 1" diameter rubber cover), slacken the adjuster screw and then tighten until it just makes contact, then back off a gnats and do up the lock nut. Then adjust the cable at the bars to suit.
If you have over tightened things previously then the clutch might have been slipping for a bit and worn
| Yetiboy |
| Yetiboy |
The last post was made 15 years, 156 days ago. Instead of replying here, would creating a new thread be more useful? |
