| alan0259 |
 alan0259 Nova Slayer
 Posted: 09:13 - 31 May 2011 Post subject: CBR600F3 problems |
Hi All,
I ran out of fuel last week whilst out and forgot to put it on reserve before it cut out completely, this has happened before and it takes a lot of shaking the bike to get it to start again (assuming the fuel isn't hitting the straw being so low), after about 15 attemps it seemed I had drained my battery, I managed to put £5 of fuel in and managed to bump start it, it was spitting something (fuel?) out of the exhaust for a few secs and then went back to normal.
A week later (after not riding it since the fuel thing) I took the baffle out of my Carbon Can Co and took it out for an hour, the bike was idling at some traffic lights and just cut out with no warning, I tried the starter button and it was compeltely gone, I had to bump start it again (plenty of fuel this time!), and noticed that when it was in 3rd/4th gear at 30/40mph it would splutter a little on full throttle (never done this before).
Does it sound like...
I flooded the engine trying to start the bike on reserve?
The bike doesn't have the right air/fuel mixture without the baffle?
The 15 failed attempts have killed the battery?
It 'baffles' me how the battery could be nackered when it started up fine after a week being stood still
Thanks! |
| supZ |
 supZ World Chat Champion
 Posted: 09:34 - 31 May 2011 Post subject: |
when you say 'tried the starter button and it was completely gone' do you mean it wouldnt even turn over or it turned over but wouldnt start?
if the latter id be looking more at fuel filters/blocked breathers etc.. but the former id say you've managed to knacker your battery OR your rec/reg has failed meaning its not charging it which is a common issue for the cbr6's
spluttering on throttle will indeed be the fact you've removed the baffles. remember they're carbed not injection so cant adapt to changes in the airflow without help. (rejetting)
i doubt starting it on reserve would have caused any problems. the fuel filters there to stop any crap from being dragged into the system and on reserve you still have plenty of fuel to allow you to get going.
and it wouldnt be flooded if you'd left it a week. petrol evaporates very quickly, although if its old fuel you can end up depositing residue in the carbs and clocking them up. ideally you'd want to strip and clean them but you can sometimes get away with taking the pipe off the fuel tank and blowing down it. can sometimes clear any crap and allow you to start it up and blow out the crap.
out of interest, when you open the fuel cap do you hear a rush of air? if you do that might explain the starting issues and cutting out. it'll be an airlock. check your breathers, make sure they're clear and not kinked and make sure the overflow just under the cap isnt blocked either.
hopefully some of that can help  ____________________ CBR954RR - Daily toy
CBR600RR - Trackbike |
| alan0259 |
 Posted: 11:07 - 31 May 2011 Post subject: |
Cheers supZ,
I have opened the fuel cap since to fill it with fuel and never heard anything, i'll give it a try later though and will listen for it.
When I tried the button (after it cut out at traffic lights) it didn't turn over at all, just pure silence. I forgot to mention that I always ride with my lights on, and that the oil light was dimmer than usual, when I turned the lights off it went bright again.
Is there a reason that once it cuts out from no fuel, that when I put it on reserve it never starts back up easy? Does the choke need to be on? Or do you need to leave it a while? Haven't yet understood the reserve system!
When I mentioned the engine flooding, I thought this was the case when I tried so many times to get it started (with only the fuel reserve), this was making a 'dump valve' kind of noise after a while when it was turning over, like an air noise, since I put fuel in the bike and bump started it this noise has now gone.
It's just the fact that it cut out on idle that worrys me, nothing to do with the baffle being removed? Any tests I can do with the battery/rec?
Thanks again. |
| supZ |
| alan0259 |
 Posted: 12:07 - 31 May 2011 Post subject: |
Thanks, i'll try the multi meter thing some time.
Its done around 21k and it's a 1998, it hasn't had it's major service yet, and I've just bought my first house so funds are mega tight at the minute, looking to get the service done just before winter time.
Wouldn't like to change/inspect the plugs myself either
Ran faultless up until it cut out, hopefully it's just something to do with the battery. Even when I bumped it yesterday it ran another 15 mile or so with no problems. |
| whitedevil |
 whitedevil World Chat Champion
| Robby |
 Robby Dirty Old Man
| alan0259 |
| whitedevil |
The last post was made 15 years, 104 days ago. Instead of replying here, would creating a new thread be more useful? |
