| Retro-Man |
 Retro-Man Traffic Copper
 Posted: 19:27 - 21 Aug 2004 Post subject: cg125 engine kicking |
Hi All
First post so please bear with me.
I have a 1999 cg125 which is my first ever bike. the engine starts and runs at idle fine how ever there appears to be two issues
1. It will not run (hot or cold) without choke,although it does run fine with partial choke. but more concerning is that at the top end of the rev range in any gear but more noticeable in top the whole bike seems to lurch forward/holdback repeatedly. this is alleviated by backing off the throttle slightly. I have three theories of my own but am looking for some more experienced opinions.
1. this is normal operation of cdi rev limiter
2. there is a carb/fuel issue
3. (not likely) but it has been hinted at that my chain may have stiff links
I am loathed through my lack of experience to remove /strip carb
but I did put some fuel system cleaner in the tank this morning which seemed to make a small difference
any tips for a newbie appreciated |
| alains |
 alains World Chat Champion
| Retro-Man |
| dibbster |
 dibbster Nearly there...
 Posted: 00:08 - 22 Aug 2004 Post subject: |
Its definately not 1, I would think 2 would be your most likely problem. ____________________ Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's
www.bikepics.com/members/dibbster |
| stinkwheel |
 Posted: 02:05 - 22 Aug 2004 Post subject: |
Keep it outside? Been riding a lot through the week?
You could have water in the petrol which classically causes 'kangarooing' and general shitty running. Simplest cure is to put an anti-water fuel additive in the tank. CGs used to have a sediment bowl on the fuel tap, if yours does, carefully unscrew it (without spilling the contents) and have a look inside. If there is water in there you will be able to see it as small (or one big) droplets under the petrol.
I'd make sure the air filter is clean too, and that the breather in the petrol tank cap is unobstructed (blow through or try running with the cap open and see if the problem goes away) before I started buggering about with the carb. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| ts50x0 |
 ts50x0 Spanner Monkey
| Retro-Man |
 Posted: 13:35 - 22 Aug 2004 Post subject: |
cheers to everybody for the advice
one thing seems to settled (its not normal)
the general opinion seems to be a fuel issue. all I have to do now is find the time to fix it
LOL
cheers everybody ____________________ https://domharnessphotography.webs.com |
| Retro-Man |
 Posted: 18:29 - 28 Aug 2004 Post subject: |
had time today to remove carb (dont know what I was worried about ) quite a simple strip down, clean, blow out jets and reassemble. fitted carb back to bike and tested guess what bike runs sweet.
cheers to all for the advice  ____________________ https://domharnessphotography.webs.com |
The last post was made 22 years, 45 days ago. Instead of replying here, would creating a new thread be more useful? |
