| FretGrinder |
 FretGrinder World Chat Champion
 Posted: 18:53 - 31 May 2011 Post subject: GP100 not starting - UPDATE - Rebuild completed |
OK guys, here's an interesting one for you...
The lad that bought my GP100 from me is having problems with it.
He went and put fuel in the bike and it wouldn't start after. He left it at the petrol station and picked it up after work.
He replaced the spark plug, tried to start it and there was a bang from the "front end of the bike"
I went down today to have a look and I did the following -
- Checked spark and there is a strong spark and the gap is correct. Spark plug is also the correct type.
- Checked the piston to see of it had any holes, piston is fine.
- Stripped the carb down, blew all the jets with compressed air, float is correct and fuel is getting through
- Compression is good, correct amount for the bike
- checked the exhaust, bit of carbon in there, but nothing major that would cause a blockage.
- fuel filter is fine
- Won't fire on a bump start
The only things left that I can think of are -
- The ignition timing is retarded
- Not getting enough voltage for the spark
Any advice would be greatly appreciated.
Cheers  ____________________ Yamaha MT-09
ಠ_ಠ
| hazza |
 hazza World Chat Champion
| FretGrinder |
| N cee thirty |
 N cee thirty Banned
| hazza |
| hazza |
| FretGrinder |
| N cee thirty |
 N cee thirty Banned
| temeluchus |
| N cee thirty |
 N cee thirty Banned
| temeluchus |
| cb1rocket |
 cb1rocket World Chat Champion
| Wyldkat |
 Wyldkat Nitrous Nuisance
 Posted: 15:22 - 10 Jun 2011 Post subject: |
I'm glad that someone has already asked this because I'm having a similar problem with my GP.
Basically - last time I rode it (probably about 4 months ago now, has been charged since) I started having electrical problems which are now sorted. Now there is no spark.
I've checked the following -
new plug/checked gap;
New plug cap;
Replaced condensor (soldered, good joint);
Replaced the points;
Stator plate put back in same position as it came off (marked position for accuracy)
Was going to replace ignition coil but have been advised that they are not normally the thing that buggers up!?
Connections to/from the battery/rectifier/stator plate (inc. coils etc) ignition coil and plug etc are all good.
The next thing I'm trying is the timing/adjustment of points.
Stumped now and getting p***ed off!
Any ideas? ____________________ Oldie - 1987 Suzuki GP100 SOLD!
Current (as of 12/7/12) 2001 Honda Varadero 125 |
| Nope. |
 Nope. World Chat Champion
 Posted: 15:28 - 10 Jun 2011 Post subject: |
| Wyldkat wrote: | I'm glad that someone has already asked this because I'm having a similar problem with my GP.
New plug cap;
Any ideas? |
Yeah, next time start a new thread as opposed to resurrecting old ones. Ill let you off this time considering that its only a couple months old
If its not sparking at all I guess it could be the coil. Do you have a friend you could borrow one off too try it? Have you actually checked the battery power with a meter to check its actually putting out the correct amount of power? ____________________ Former: Derbi GP1 50, Sachs XTC 125, Suzuki GSXR 400 GK73A, Kawasaki ZX7R, Suzuki DR250, Yamaha RD350
Current: 2011 Yamaha XT660Z Ténéré, 2003 Yamaha YZR-R1 5PW (In Build), 2009 Kawasaki ZZR1400 |
| Wyldkat |
 Posted: 16:24 - 10 Jun 2011 Post subject: |
computid - my apologies for 'resurrecting' old posts but there also seems to be a dislike to starting a topic that has already been somewhat covered....no win?!!
No I can't borrow one but I will try testing the battery, forgot about that actually thanks.  ____________________ Oldie - 1987 Suzuki GP100 SOLD!
| FretGrinder |
| N cee thirty |
 N cee thirty Banned
| FretGrinder |
| cb1rocket |
| FretGrinder |
| FretGrinder |
 Posted: 17:53 - 19 Jun 2011 Post subject: |
After I cleaned off the piston I noticed that it had "0.50" on it. Does this mean that the barrel has already had a rebore? Does this also mean that I have to get an identical piston?
https://i49.photobucket.com/albums/f292/d0xicle/Gp100%20engine%20overhaul/oversizepiston.jpg
As there is no scoring that I can see, would I be safe just dropping in the same size of piston with suitable rings? ____________________ Yamaha MT-09
ಠ_ಠ |
| 27cows |
 27cows World Chat Champion
 Posted: 20:38 - 19 Jun 2011 Post subject: |
Yep, that's .50mm oversize. Think you can get at least 1mm oversize for the GP100, maybe even 2mm. So you should be able to have another rebore on that barrel. You might get away with just a new .50 piston...but I doubt it. Probably do the same again.
GP motors tend to be pretty fragile. It'll be the main bearings next, trust me  ____________________ The RXS100: vehicle of choice for Chuck Norris |
| cb1rocket |
 Posted: 20:52 - 19 Jun 2011 Post subject: |
yes its been rebored before, which is a 1st stage rebore ie its only been rebored once before. There does appear to be some light scoring to the barrell but you could get away with using the same piston size and new rings. It doesn't look as bad as when my gp100 decided to shatter itself to pieces.
I would go for a new rebore and new next size up piston rather than waste time trying to make use of just a new piston and rings. Your know its been done properly rather than trying to bodge it, and your also know it will last another 15 - 20k miles then.
Check there is no debris in the crank case and give it a thorough wash out with petrol/parafin mix or a hose pipe with water and then rinse and fill with oil and drain several times. Repeat if necessary.
Also check the big end bearings are good that there is no vertical movement. Side to side movement is ok but no vertical.
see my thread on what happend to mine:
https://www.bikechatforums.com/viewtopic.php?t=204850&highlight=gp100 |
| FretGrinder |
 Posted: 20:16 - 03 Jul 2011 Post subject: |
Another update on the gp100 -
One of my dads friends had a look at the cylinder barrel and suggested that I would get away with just honing it.
I borrowed a honing tool and now the barrel looks a lot smoother.
I sourced a new piston - Potenza (made in japan) with subsequent rings, gudgeon pin and circlips.
I set about rebuilding the engine today. I put back both the crankcase halves, used new gaskets and some gasket sealant as there was a few chips in the crankcase where someone had chipped away some of the surface when levering it off.
I then fitted the new piston, smeared some 2 stroke oil on it and reinserted the barrel and fitted the new gaskets.
I then set about sorting out the timing. I set the piston to 1.87mm BTDC with the aid of a vernier caliper and then set the stator accordingly. Followed by setting the points gap.
I reattached the oil pump, the carb, put on the flywheel. I bled the oil pump and primed the carb.
I then did a compression test which gave a reading of around 150 PSI, I'm guessing this pretty good?
Then it came to the pivotal moment - will it start.
Believe it or not it started after 2 kicks, once I realised that the kill switch was on.
Everything then started heading south. The bike stopped, I tried to start it again and it kicked back with quite a bit of force. After careful inspection it seemed that I forgot to tighten the flywheel up and the bike had sheared the bloody woodruff key!
Now-
Are woodruff keys fairly generic items?
I have scoured teh internet without any sign of one for this bike, but they seem to pop up all over the internet, without any specific reference to any car or bike.
Luckily everything else is tickety-boo.
- I can select 1st and 2nd gears as normal, and then return to neutral
- No backfiring
- No oil leaks ____________________ Yamaha MT-09
ಠ_ಠ |
| Nexus Icon |
 Nexus Icon World Chat Champion
The last post was made 14 years, 175 days ago. Instead of replying here, would creating a new thread be more useful? |
