| stuartadair |
 stuartadair Crazy Courier
 Posted: 22:08 - 31 May 2011 Post subject: EXUP Cables |
Hello all
I'm thinking about buying an FZR1000 but the seller says that the EXUP cables have been removed. He says it doesnt affect the bike running...
a) What are EXUP cables ?
b) Am I worried if they are missing ?
Thanks
Stu  |
 Posted: 22:31 - 31 May 2011 Post subject: |
EXUP is the exhaust valve. It is a valve in the bottom of the exhaust that rotates to open and close, with a servo motor under the seat to operate it. Couple of cables go from the servo to the valve.
Chances are it the cables have been removed then the valve has seized. It is there to allow an exhaust design and cam profile set up for high revs power, which normally knackers up bottom end / midrange. The valve opens at high revs to allow things to work properly, while at low revs it is closed to screw up the pressure waves that otherwise knacker up the lower rpm power.
If the valve isn't working then it will either be open or closed. If open it will be missing a load of bottom end power. If closed it will be missing a load of top end power.
| 69chris |
 69chris Trackday Trickster
 Posted: 23:52 - 31 May 2011 Post subject: |
if its the fzr im thinking of id be more worried about the hideous handlebars/ risers than the missing exup cables  |
| stuartadair |
 Posted: 06:48 - 01 Jun 2011 Post subject: |
Many thanks. I can get both servo and cables for <£50 on ebay so I'll take that into account when I'm haggling
Risers would have to go  |
| jimbothe |
 jimbothe World Chat Champion
 Posted: 07:35 - 01 Jun 2011 Post subject: |
Alternatively you could also have the carbs rejetted and put free-flowing exhaust headers on there.
This would eliminate the seizure problems that exups are reknowned for. ____________________ Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle |
| MarJay |
 MarJay But it's British!
The last post was made 15 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
