kle500 gpz500 engine swop
wildmetal
PostPosted: 13:59 - 31 May 2011    Post subject: kle500 gpz500 engine swop Reply with quote
have fitted a gpz500 engine in my kle500 . but it wont start any advice on what it could be .
PostPosted: 14:39 - 31 May 2011    Post subject: Reply with quote
What model GPZ engine?
Did you swap the CDI unit too?
Which carbs did you use?
I have some experience in this matter:
https://i48.photobucket.com/albums/f216/stinkwheel/c920f33e.jpg
wildmetal
PostPosted: 15:01 - 31 May 2011    Post subject: kle500 gpz500 engine swop Reply with quote
the engine i been told is out of a a reg bike . using standard kle500 carbs and air box . also the kle cdi . i know that the flywheel and pick-ups are different on the gpz engine . i have tryed to get the kle500 rotor off but have busted 2 off the magnets . do you know what size puller i will need to remove the rotor . know any were i can get a cheap replacement ?
PostPosted: 15:15 - 31 May 2011    Post subject: Reply with quote
You need a puller to get the flywheel off the gpz engine. And the flywheels lose their magnets easily although you shouldn't have been pulling on the flywheel anywhere close to them.
The difference between the early and late gpz ignitions is the number of pickups, which means a different flywheel with different ignition triggers on it. Not sure if the early flywheel cover will locate the late ignition pickup in the correct place.
You say it doesn't start. Does it crank over? Does it spark? Which flywheel / ignition cover and pickups / cdi are you using which are failing to start?
PostPosted: 15:30 - 31 May 2011    Post subject: Reply with quote
You are correct to use the KLE carbs though, airbox differences mean it won't run with the GPZ jetting.
The ignition advance curve is different between the KLE and the GPZ. When I did it I used the GPZ CDI.
You have an early model GPZ500 motor there which has a double ignition timing pickup coil and a single trigger on the rotor. The KLE has a single pickup and a double trigger on the rotor.
So how did you connect the GPZ motor to the KLE CDI?
I would suggest getting yourself an early model GPZ IC igniter box and fitting this which will set you back £30-40.
I should be able to help you with how to wire it in because I have manuals for both bikes. Should fit in there with the standard wiring loom, just a case of connecting the correct wire to the correct terminal on the IC igniter.
wildmetal
PostPosted: 18:57 - 31 May 2011    Post subject: kle500 gpz500 engine swop Reply with quote
the gpz motor still has the rotor on it . i swopped the casing over off the kle hoping that would do it ,but no . you are correct in that the pick-ups are not the same . the gpz has 2 the kle 1 . i do have the other casing off the gpz . could i fit the gpz rotor and casing and then add the gpz cdi
PostPosted: 22:09 - 31 May 2011    Post subject: Reply with quote
You need the flywheel, cdi and pickups (possibly cover) to match. Problem is any wiring connectors to the loom.
PostPosted: 23:18 - 31 May 2011    Post subject: Reply with quote
I've always been of the oppinion that the CDI should go with the engine. Keep all the original internals that went with the GPZ engine and attach them to the GPZ CDI unit.
The main trouble I can see is that the wiring diagrams show 9 wires in a row but the CDI has a multi connector block with 2 rows of pins.
I fucking hate it when they do this.
I'd need a pin layout diagram at best, or at least a picture of a CDI connected up or the connector block that plugs into it so i can see which wire goes to which pin.
wildmetal
PostPosted: 10:51 - 06 Jun 2011    Post subject: kle500 gpz500 engine swop Reply with quote
i think the easy option here would be to just get a new kle flywheel
PostPosted: 10:56 - 06 Jun 2011    Post subject: Reply with quote
Electrically that will be the easiest as then (assuming you swap the crank cover and pickups) you have everything matching.
Not sure how well it will run though as then you will have the ignition timing for the detuned KLE engine which won't match the more tuned up GPZ engine.
PostPosted: 11:02 - 06 Jun 2011    Post subject: Re: kle500 gpz500 engine swop Reply with quote
After market KLE rotor.
And for a puller buy an M18 Extra Fine bolt (M18x1.5).
wildmetal
PostPosted: 14:29 - 06 Jun 2011    Post subject: kle500 gpz500 engine swop Reply with quote
god that rotors not cheap . think i will hang out for one off flebay . you never know one may come along
PostPosted: 14:36 - 06 Jun 2011    Post subject: Reply with quote
That is dirt cheap compared to an original Kawasaki part new. Think new from Kawasaki they are about £350.
Mick34123
PostPosted: 13:29 - 15 Aug 2011    Post subject: Hi all first post Reply with quote
Hi all sorry for bringing this old thread up
I have the same problem, bought a n reg gpz500 and fitted engine and ancillaries to my kle, was running for abit then died (compression), swapped the kle engine back in using the gpz's loom ic box and magneto, using the gpz carbs too lost the kle ones
Bike turns over etc just does not fire, getting a spark and there is fuel on the plugs after i try starting it
Any help would be great thanks Very Happy
wildmetal
PostPosted: 13:37 - 15 Aug 2011    Post subject: kle500 gpz500 engine swop Reply with quote
Hi i would do a compresion test . i was getting a spark but i turned out that the piston rings were stuck in and one was broken . i ended up changing the engine from a gpz500 . i did however need to change the rotor and flywheel from the kle500 . it was then running ok
Mick34123
PostPosted: 13:46 - 15 Aug 2011    Post subject: Reply with quote
Compression on the engine is fine
Thing is the rotor etc from the kle was shattered thats why i replaced the bike with a gpz unit
Any other ideas ?
PostPosted: 14:05 - 15 Aug 2011    Post subject: Reply with quote
If you are getting compression, fuel and a spark at the right time it should start.
Stick a timing light on it and check the ignition timing.
Mick34123
PostPosted: 14:10 - 15 Aug 2011    Post subject: Reply with quote
In my opinion thats what is wrong
its using all the gpz electrical side which did work when it was all on the gpz engine.
PostPosted: 14:25 - 15 Aug 2011    Post subject: Reply with quote
I would be far from certain, but it is an easy one to check. Only really likely though if the flywheel is triggering the ignition in a different position.
The last post was made 15 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 104.81 Kb
