i need some help
phonesurgeon
PostPosted: 14:12 - 01 Jun 2011    Post subject: i need some help Reply with quote
Need to change front tyre and brake pads...
The frigging pinch bolts on the fork are seized solid...
Took it to my local garage... after they applied heat... still nothing
and the bolts are rounding off! (allen bolts)
What my next option? was thinking to put the bolt extractors...
but drilling a steel bolt... knowing the fork bottom casing is alluminium...
consequences could be disastrous...
Any help?
cb1rocket
PostPosted: 14:56 - 01 Jun 2011    Post subject: Reply with quote
Allen key welded to bolt head and undo - job done. If its rounding off then the allen keys must be a very poor fit.
Are the bolts recessed inside the fork bottoms?
phonesurgeon
PostPosted: 15:10 - 01 Jun 2011    Post subject: Reply with quote
Allen bolts are recessed in the fork casing by 2mm.
allen key was good fit (bolt rusted) and even garage applied heat and still didn't budge...
Just had a thought... still got some caustic soda left... hmmm maybe?
PostPosted: 15:14 - 01 Jun 2011    Post subject: Reply with quote
Try hammering in a torx head?
phonesurgeon
PostPosted: 15:20 - 01 Jun 2011    Post subject: Reply with quote
G only problem is that i haven't got any torx keys...
PostPosted: 15:31 - 01 Jun 2011    Post subject: Reply with quote
Unfortunate; I was in Harrogate yesterday evening and could have brought you a selection of old ones I don't care about to try out.
Have you tried soaking it in WD40?
Giving it some decent whacks with a hammer?
Doing it up slightly first?
Freezer spray to go with the heat?
phonesurgeon
PostPosted: 15:41 - 01 Jun 2011    Post subject: Reply with quote
G have a look at this... this is the pigging problem...
https://i174.photobucket.com/albums/w81/phonesurgeon/Nikon%20D40X/DSC_3081.jpg
Tried heat... wd40... doing it up slightly... hammer... tapped it gently... tap it vigourosly... nothing.
I am considering using caustic soda on it
PostPosted: 15:45 - 01 Jun 2011    Post subject: Reply with quote
I suspect the problem there is not the threads, but the caps binding in the corroded alloy. I suggest trying freeze and release on it.
PostPosted: 15:59 - 01 Jun 2011    Post subject: Reply with quote
I'd ideally try some heat with some freeze and release.
Doubt it's worth it, but if you can make it over to Keighley in an evening, don't mind giving a hand to see what we can do with stuff I've got here.
phonesurgeon
PostPosted: 16:12 - 01 Jun 2011    Post subject: Reply with quote
G keighley is not a million miles from me...
And i appreciate your offer...
its only a case of when'sa good day for you?
cb1rocket
PostPosted: 16:14 - 01 Jun 2011    Post subject: Reply with quote
I would still weld an old allen key with that.
don't use caustic soda, it will eat the alloy. But as others have said, try freeze ad release spray, and loads of wd-40 or plus gas etc.
I think the only way on that is to weld and undo........its looks like its laughing at you.
PostPosted: 16:36 - 01 Jun 2011    Post subject: Reply with quote
Now that I've said that, realised I'm actually busier than I thought.
Any time this evening is fine, or later tomorrow evening.
Drop me a PM.
phonesurgeon
PostPosted: 16:46 - 01 Jun 2011    Post subject: Reply with quote
G PM sent
PostPosted: 17:36 - 01 Jun 2011    Post subject: Reply with quote
Failing everything. I once had a similar arrangement and landed up hacksawing them in half through the split in the bottom of the fork leg. I then levered the bits with the head in out by hammering an old screwdriver in the gap I just sawed then used the hole they left as a drill guide.
As it happens, after only a few turns of the drill, it grabbed the stubs and screwed them all the way out through the other side.
I preferr the idea of welding an allen key to them though.
Clear case for using an air impact wrench in the first place as soon as you/they realised they weren't going to move.
The last post was made 15 years, 105 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 79.43 Kb
